Aller au contenu principal
Black and Decker Toast R Oven Door Spring Mechanism Replacement
Ce dont vous avez besoin
  1. Black and Decker Toast R Oven Door Spring Mechanism Replacement, How to clean out a Black and Decker Toast R Oven: étape 1, image 1 de 1
    • Make sure that the toaster is unplugged before you begin.
    • Turn the toaster over with its backside face down.
    • Remove the two Phillips #4 1cm screws that attach the side panels.
  2. Black and Decker Toast R Oven Door Spring Mechanism Replacement: étape 2, image 1 de 2 Black and Decker Toast R Oven Door Spring Mechanism Replacement: étape 2, image 2 de 2
    • Pull downwards (towards the bottom of the unit) and outward to remove the side panels.
  3. Black and Decker Toast R Oven Door Spring Mechanism Replacement: étape 3, image 1 de 1
    • Remove the metal vent piece that is below the door.
    • This should slide off easily once both of the side panels are removed.
  4. Black and Decker Toast R Oven Door Spring Mechanism Replacement: étape 4, image 1 de 1
    • Remove the two Phillips #4 1 cm screws, which connect the bottom panel to the unit.
  5. Black and Decker Toast R Oven Door Spring Mechanism Replacement: étape 5, image 1 de 1
    • Remove the crumb tray (the bottom, metal panel) from the toaster unit.
  6. Black and Decker Toast R Oven Door Spring Mechanism Replacement: étape 6, image 1 de 1
    • Remove the aluminum strip from the bottom of unit; this is the piece that is directly under the door.
  7. Black and Decker Toast R Oven Door Spring Mechanism Replacement: étape 7, image 1 de 1
    • Remove the knobs by pulling them upward; they should slide right off.
    • When placing the knobs back on the unit, make sure the semicircle notch fits correctly in the hole so that the knobs don't fall off.
  8. Black and Decker Toast R Oven Door Spring Mechanism Replacement: étape 8, image 1 de 1
    • Unhook the bottom of the the display panel from the toaster unit.
    • It will be a little tough to pry off, but don't be afraid to be forceful. You can use your hands, or pliers, to bend the metal piece backwards.
  9. Black and Decker Toast R Oven Door Spring Mechanism Replacement: étape 9, image 1 de 1
    • Begin to detach the back panel from the toaster unit.
    • Then, unhook the rest of the display panel.
    • This will also be a little tough to get off, but don't be afraid to be forceful.
  10. Black and Decker Toast R Oven Door Spring Mechanism Replacement: étape 10, image 1 de 1
    • Finish removing the outside cover by lifting the lid upward.
  11. Black and Decker Toast R Oven Door Spring Mechanism Replacement: étape 11, image 1 de 1
    • Remove the four Phillips #4 1 cm screws from the back of the unit.
  12. Black and Decker Toast R Oven Door Spring Mechanism Replacement: étape 12, image 1 de 1
    • Now, you can clean the outside units of the toaster oven.
  13. Black and Decker Toast R Oven Door Spring Mechanism Replacement: étape 13, image 1 de 1
    • Remove the the heating coil protection bar from the toaster unit by first pulling out the left side.
  14. Black and Decker Toast R Oven Door Spring Mechanism Replacement, Door Spring Mechanism: étape 14, image 1 de 2 Black and Decker Toast R Oven Door Spring Mechanism Replacement, Door Spring Mechanism: étape 14, image 2 de 2
    • Use the screwdriver to remove the spring from the unit.
    • Place the screwdriver inside the spring loop.
    • Pull to unhinge the spring from the back panel.
  15. Black and Decker Toast R Oven Door Spring Mechanism Replacement: étape 15, image 1 de 1
    • Remove the spring from the door mechanism by pulling it off.
    • Replace the old spring with a new spring.
    • When inserting a new spring, make sure that the spring is connected to the lower hole of the back panel (the hole above is used for the back casing).
2 autres ont terminé cette réparation.
Jonathan
Membre depuis le 09/18/12
281 Réputation
5 tutoriels rédigés
Équipe
Cal Poly, Team 2-10, Propen Fall 2012 Membre de l'équipe Cal Poly, Team 2-10, Propen Fall 2012
CPSU-PROPEN-F12S2G10
4 membres
5 tutoriels rédigés
2 commentaires
Great guide! Very clearly-written and accompanying photos captured the process effectively.
Mo Poppins - Réponse
Thanks for sharing,
It's very informative for me, I really enjoy this content.
I also have Content about <a href="https://link accessmastersinc.com/"> emergency gate repair</a>
Cheers.
waleed - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 2
7 derniers jours : 20
30 derniers jours : 70
Total : 13,929
