Introduction
In order to replace to On/Off switch, you will once again have to take apart the whole unit to get to that part.
Ce dont vous avez besoin
Turn the toaster over with its backside face down.
Remove the two Phillips #4 1cm screws that attach the side panels.
Remove the two Phillips #4 1 cm screws that were under the faceplate.
To reassemble your device, follow these instructions in reverse order. It will look like the faceplate is still bent out, but after you put the screws back in it will come back into place.
2 autres ont terminé cette réparation.
