Introduction
This guide shows you how to replace the screen from your BlackBerry 7100g.
Turn over your BalckBerry 7100g so that the back cover is facing up.
  • Turn over your BalckBerry 7100g so that the back cover is facing up.
  • Locate the battery cover release button near the bottom of the back panel.
Ajouter un commentaire
Push down on the release button with one thumb. Slide the battery cover off with the other thumb. Slide the battery cover off with the other thumb.
  • Push down on the release button with one thumb.
  • Slide the battery cover off with the other thumb.
Remove the battery from the battery housing by flipping up the top of the battery.
  • Remove the battery from the battery housing by flipping up the top of the battery.
Locate the silver strip near the top of your BlackBerry. Use a plastic opening tool to pry off the edge of the silver lining. Slide the tool along the length of the silver strip to completely remove it.
  • Locate the silver strip near the top of your BlackBerry.
  • Use a plastic opening tool to pry off the edge of the silver lining.
  • Slide the tool along the length of the silver strip to completely remove it.
Do not lose the screws. They are quite small and can easily be misplaced. Locate and unscrew the four (4) screws using a T6 screwdriver.
  • Do not lose the screws. They are quite small and can easily be misplaced.
  • Locate and unscrew the four (4) screws using a T6 screwdriver.
The keypad cover may fall out of the housing when prying the housing apart. Tightly pinch the top of the front and back halves of the housing. Carefully pry the two halves of the housing apart.
  • The keypad cover may fall out of the housing when prying the housing apart.
  • Tightly pinch the top of the front and back halves of the housing.
  • Carefully pry the two halves of the housing apart.
You can now easily remove the "guts" of the phone from the housing.
  • You can now easily remove the "guts" of the phone from the housing.
Turn the "guts" over so the speaker is facing up. Locate and unscrew the four (4) screws near the bottom of the motherboard, using a T6 screwdriver. Separate the battery housing from the motherboard.
  • Turn the "guts" over so the speaker is facing up.
  • Locate and unscrew the four (4) screws near the bottom of the motherboard, using a T6 screwdriver.
  • Separate the battery housing from the motherboard.
Pull the keypad off of the motherboard.
  • Pull the keypad off of the motherboard.
    • It should come off with little effort. If not, there are several tabs that can be released on either side of the keypad.
Locate the ribbon connector below the bottom of the screen. Use a spudger to flip up the connector.
  • Locate the ribbon connector below the bottom of the screen.
  • Use a spudger to flip up the connector.
Locate the four (4) white tabs that attach the screen to the motherboard. Carefully detach the tabs from the motherboard. The screen can now be removed from the motherboard.
  • Locate the four (4) white tabs that attach the screen to the motherboard.
  • Carefully detach the tabs from the motherboard.
  • The screen can now be removed from the motherboard.
Adriel Salinas
Membre depuis le 11/04/2010
30 Réputation
2 tutoriels rédigés
Équipe
Cal Poly, Team 25-87, Amido Spring 2010 Membre de l'équipe Cal Poly, Team 25-87, Amido Spring 2010
CPSU-AMIDO-S10S25G87
4 membres
8 tutoriels rédigés
Voir les statistiques:
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 2
Total : 1,674
