Aller au contenu principal
BlackBerry 7280 Front Case Replacement
Ce dont vous avez besoin
  1. BlackBerry 7280 Front Case Replacement, Battery: étape 1, image 1 de 3 BlackBerry 7280 Front Case Replacement, Battery: étape 1, image 2 de 3 BlackBerry 7280 Front Case Replacement, Battery: étape 1, image 3 de 3
    • With your thumb press down on the locking- button on the back of the BlackBerry 7280.
    • Slide the battery cover off the device.
  2. BlackBerry 7280 Front Case Replacement: étape 2, image 1 de 2 BlackBerry 7280 Front Case Replacement: étape 2, image 2 de 2
    • Remove the lithium-ion battery from the back of the device using your index finger.
  3. BlackBerry 7280 Front Case Replacement, SIM Card: étape 3, image 1 de 3 BlackBerry 7280 Front Case Replacement, SIM Card: étape 3, image 2 de 3 BlackBerry 7280 Front Case Replacement, SIM Card: étape 3, image 3 de 3
    • Hold the device with both hands.
    • Lift the SIM card holder using your thumb and index finger.
    • Remove the SIM card from the device.
  4. BlackBerry 7280 Front Case Replacement, Back Case: étape 4, image 1 de 2 BlackBerry 7280 Front Case Replacement, Back Case: étape 4, image 2 de 2
    • Using a Torx T6 screwdriver, remove all six 1/8 inch screws (marked in red) from the back case. Set screws aside.
    • The SIM card has been removed here to prevent damage to the card. This is recommended, but not not required.
  5. BlackBerry 7280 Front Case Replacement: étape 5, image 1 de 2 BlackBerry 7280 Front Case Replacement: étape 5, image 2 de 2
    • Use the plastic opening tool to pry the back case away from the front case.
  6. BlackBerry 7280 Front Case Replacement, Front Case: étape 6, image 1 de 2 BlackBerry 7280 Front Case Replacement, Front Case: étape 6, image 2 de 2
    • Using a Torx T6 screwdriver, remove the lone 1/8 inch screw that holds the upper metal bracket onto the larger metal bracket. Set aside the screw and the bracket.
  7. BlackBerry 7280 Front Case Replacement: étape 7, image 1 de 2 BlackBerry 7280 Front Case Replacement: étape 7, image 2 de 2
    • Remove the front plastic case from the metal bracket.
Andrew Catlin
Membre depuis le 03/11/13
16 Réputation
3 tutoriels rédigés
Équipe
Clemson, Team 12-2, Benson Spring 2013 Membre de l'équipe Clemson, Team 12-2, Benson Spring 2013
CLEM-BENSON-S13S12G2
4 membres
11 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 1
30 derniers jours : 4
Total : 203
