Aller au contenu principal
BlackBerry 7290 Side Button Replacement
Ce dont vous avez besoin
  1. BlackBerry 7290 Side Button Replacement, Battery: étape 1, image 1 de 3 BlackBerry 7290 Side Button Replacement, Battery: étape 1, image 2 de 3 BlackBerry 7290 Side Button Replacement, Battery: étape 1, image 3 de 3
    • Apply pressure to the lock button on the back of the device.
    • Slide the battery cover down towards the bottom of the device, revealing the battery compartment.
  2. BlackBerry 7290 Side Button Replacement: étape 2, image 1 de 3 BlackBerry 7290 Side Button Replacement: étape 2, image 2 de 3 BlackBerry 7290 Side Button Replacement: étape 2, image 3 de 3
    • Locate groove along the right side of the battery compartment.
    • Remove battery by prying between the battery and the groove.
  3. BlackBerry 7290 Side Button Replacement, SIM Card: étape 3, image 1 de 1
    • Slide the SIM card holder to the left to unlock the SIM card.
  4. BlackBerry 7290 Side Button Replacement: étape 4, image 1 de 2 BlackBerry 7290 Side Button Replacement: étape 4, image 2 de 2
    • Lift the SIM card holder up.
    • Gently remove the SIM card from the SIM card holder by sliding the card along the railing.
  5. BlackBerry 7290 Side Button Replacement, Side Button: étape 5, image 1 de 1
    • Locate the four screws along the perimeter of the back casing.
    • Remove the four top screws using a T-6 torx screwdriver.
    • The top four screws are .413 inches.
  6. BlackBerry 7290 Side Button Replacement: étape 6, image 1 de 2 BlackBerry 7290 Side Button Replacement: étape 6, image 2 de 2
    • Locate two screws within the lower edge of the inner compartment.
    • Remove the two bottom screws using a T-6 torx screwdriver.
    • The bottom two screws are .2 inches in length.
    • The second picture displays the device after the six screws have been removed.
  7. BlackBerry 7290 Side Button Replacement: étape 7, image 1 de 1
    • Use the plastic opening tool to apply pressure on the two clips that are located at the bottom of the phone.
  8. BlackBerry 7290 Side Button Replacement: étape 8, image 1 de 3 BlackBerry 7290 Side Button Replacement: étape 8, image 2 de 3 BlackBerry 7290 Side Button Replacement: étape 8, image 3 de 3
    • Remove the back casing from the phone by lifting the unhooked portion, then slide the casing towards the top of the device.
    • Make sure all clips holding the case together are unhooked, so no damage is caused to the case.
  9. BlackBerry 7290 Side Button Replacement: étape 9, image 1 de 2 BlackBerry 7290 Side Button Replacement: étape 9, image 2 de 2
    • Locate on the backside of the phone, a screw towards the top of the device.
    • Using a T-6 screwdriver, remove the screw.
    • After the screw has been removed, carefully lift the side button brace to reveal the side button.
Jschutt
Membre depuis le 11/05/09
79 Réputation
1 tutoriel rédigé
Équipe
Cal Poly, Team 19-6, Maness Fall 2009 Membre de l'équipe Cal Poly, Team 19-6, Maness Fall 2009
CPSU-MANESS-F09S19G6
5 membres
7 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 4
30 derniers jours : 6
Total : 3,722
