Introduction
This guide describes how to disassemble a BlackBerry 8703e keyboard.
Pièces
Aucune pièce nécessaire.
Press the button with one hand while applying downward pressure with the other hand on the middle of the phone to slide the battery cover off. Remove the battery cover completely and set it aside.
  • Press the button with one hand while applying downward pressure with the other hand on the middle of the phone to slide the battery cover off.
  • Remove the battery cover completely and set it aside.
Ajouter un commentaire
Locate the rectangular battery in the middle of the phone.
  • Locate the rectangular battery in the middle of the phone.
  • Locate the notch on the top right of the battery compartment.
  • Slide your fingernail in the notch, then lift upwards on the top of the battery to remove it from the phone.
  • Set the battery aside.
Make sure the back of the phone is facing upwards. Use the T6 Torx Screwdriver to remove all three screws.
  • Make sure the back of the phone is facing upwards.
  • Use the T6 Torx Screwdriver to remove all three screws.
MacBook Battery Fix Kits
Fix Kits Starting at $69.99
Starting at $69.99
Locate the notch in the back of the phone. Use your thumb to push up on the notch, separating the back half of the phone from the keyboard and screen in the front.
  • Locate the notch in the back of the phone.
  • Use your thumb to push up on the notch, separating the back half of the phone from the keyboard and screen in the front.
  • Slide the opening tool in between the two halves of the phone.
  • Continually apply upward pressure with the opening tool to pop the back casing off of the main body.
  • You should now have five parts: The battery cover, the battery, the screws, the back casing, and the main body of the phone.
  • Set the back casing aside.
Do not separate the front casing from the rest of the phone during this step.  Keep the phone face-down on a flat surface.
  • Do not separate the front casing from the rest of the phone during this step. Keep the phone face-down on a flat surface.
  • Remove the four screws from the back of the phone with the T6 Torx Screwdriver.
If two keyboard components and a small black port protector fall out during this step, place them to the side. Hold the phone so the screen faces downward, and remove the front casing.
  • If two keyboard components and a small black port protector fall out during this step, place them to the side.
  • Hold the phone so the screen faces downward, and remove the front casing.
The 2 keyboard components highlighted in the picture may fall out of the front casing but remain stuck together. If the keyboard components did not fall off while removing the front casing, remove them from the front casing and place them to the side.
  • The 2 keyboard components highlighted in the picture may fall out of the front casing but remain stuck together.
  • If the keyboard components did not fall off while removing the front casing, remove them from the front casing and place them to the side.
Ligne d'arrivée
Johnathon Gorski
Membre depuis le 13/01/2010
22 Réputation
4 tutoriels rédigés
Équipe
Cal Poly, Team 11-3, Forte Winter 2010 Membre de l'équipe Cal Poly, Team 11-3, Forte Winter 2010
CPSU-FORTE-W10S11G3
5 membres
4 tutoriels rédigés
Voir les statistiques:
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 1
Total : 4,502
