Pièces
Aucune pièce nécessaire.
Press the button with one hand while applying downward pressure with the other hand on the middle of the phone to slide the battery cover off. Remove the battery cover completely and set it aside.
  • Press the button with one hand while applying downward pressure with the other hand on the middle of the phone to slide the battery cover off.
  • Remove the battery cover completely and set it aside.
Ajouter un commentaire
Locate the rectangular battery in the middle of the phone.
  • Locate the rectangular battery in the middle of the phone.
  • Locate the notch on the top right of the battery compartment.
  • Slide your fingernail in the notch, then lift upwards on the top of the battery to remove it from the phone.
  • Set the battery aside.
Make sure the back of the phone is facing upwards. Use the T6 Torx Screwdriver to remove all three screws.
  • Make sure the back of the phone is facing upwards.
  • Use the T6 Torx Screwdriver to remove all three screws.
Locate the notch in the back of the phone. Use your thumb to push up on the notch, separating the back half of the phone from the keyboard and screen in the front.
  • Locate the notch in the back of the phone.
  • Use your thumb to push up on the notch, separating the back half of the phone from the keyboard and screen in the front.
  • Slide the opening tool in between the two halves of the phone.
  • Continually apply upward pressure with the opening tool to pop the back casing off of the main body.
  • You should now have five parts: The battery cover, the battery, the screws, the back casing, and the main body of the phone.
  • Set the back casing aside.
MacBook Battery Fix Kits
Fix Kits Starting at $69.99
Starting at $69.99
Do not separate the front casing from the rest of the phone during this step.  Keep the phone face-down on a flat surface.
  • Do not separate the front casing from the rest of the phone during this step. Keep the phone face-down on a flat surface.
  • Remove the four screws from the back of the phone with the T6 Torx Screwdriver.
If two keyboard components and a small black port protector fall out during this step, place them to the side. Hold the phone so the screen faces downward, and remove the front casing.
  • If two keyboard components and a small black port protector fall out during this step, place them to the side.
  • Hold the phone so the screen faces downward, and remove the front casing.
The 2 keyboard components highlighted in the picture may fall out of the front casing but remain stuck together. If the keyboard components did not fall off while removing the front casing, remove them from the front casing and place them to the side.
  • The 2 keyboard components highlighted in the picture may fall out of the front casing but remain stuck together.
  • If the keyboard components did not fall off while removing the front casing, remove them from the front casing and place them to the side.
The port protector is shown in the picture and located on the upper left side when looking at the screen of the phone. If the port protector did not fall off when removing the front casing and keyboard components, remove it and set it to the side.
  • The port protector is shown in the picture and located on the upper left side when looking at the screen of the phone.
  • If the port protector did not fall off when removing the front casing and keyboard components, remove it and set it to the side.
You should be able to easily remove the battery housing from the logic board by simply pulling them apart. You should now have 7 main components: battery cover, battery, back casing, front casing (including both keyboard pieces), port protector, battery housing and logicboard with screen attached.
  • You should be able to easily remove the battery housing from the logic board by simply pulling them apart.
  • You should now have 7 main components: battery cover, battery, back casing, front casing (including both keyboard pieces), port protector, battery housing and logicboard with screen attached.
  • You should also have 7 screws.
Caution, be careful not to break the plastic hooks highlighted in the photo, be gentle.
  • Caution, be careful not to break the plastic hooks highlighted in the photo, be gentle.
  • With the screen facing down, gently use both thumbs to push down and slightly out on the 2 highlighted hooks attaching the bottom of the screen to the logic board.
  • With caution repeat this for the 2 hooks attaching the top of the screen to the logic board.
This step requires extreme caution to avoid snapping off the small black clip highlighted in the picture. There is a small strip on the upper left of the screen that is connected to the logic board by a small black clip.  It is highlighted in the picture. Holding the screen and logic board together, use the plastic opening tool to push the clip into the up position as shown in the picture.
  • This step requires extreme caution to avoid snapping off the small black clip highlighted in the picture.
  • There is a small strip on the upper left of the screen that is connected to the logic board by a small black clip. It is highlighted in the picture.
  • Holding the screen and logic board together, use the plastic opening tool to push the clip into the up position as shown in the picture.
  • With the clip in the up position, remove the screen from the logic board.
Johnathon Gorski
Membre depuis le 13/01/2010
22 Réputation
4 tutoriels rédigés
Équipe
Cal Poly, Team 11-3, Forte Winter 2010 Membre de l'équipe Cal Poly, Team 11-3, Forte Winter 2010
CPSU-FORTE-W10S11G3
5 membres
4 tutoriels rédigés
Voir les statistiques:
Dernières 24 heures : 0
7 derniers jours : 1
30 derniers jours : 6
Total : 4,570
