Aller au contenu principal
BlackBerry Curve 8310 Trackball Replacement
Ce dont vous avez besoin
  1. BlackBerry Curve 8310 Trackball Replacement, Battery: étape 1, image 1 de 1
    • Press down on the battery release button and slide the back cover up with your thumb.
  2. BlackBerry Curve 8310 Trackball Replacement: étape 2, image 1 de 1
    • Pry from the top of the battery to pull it out.
  3. BlackBerry Curve 8310 Trackball Replacement, Lens: étape 3, image 1 de 1
    • Slide the metal sim card cover to the unlock position.
    • Remove the sim card.
    • The arrows on the sim card enclosure indicate the lock and unlock positions.
  4. BlackBerry Curve 8310 Trackball Replacement: étape 4, image 1 de 1
    • Remove the two T5 Torx screws circled at the top of the phone.
    • The T5 Torx screws may be covered by a white sticker.
  5. BlackBerry Curve 8310 Trackball Replacement: étape 5, image 1 de 1
    • Remove the red cover at the bottom of the phone.
    • You may have to work a spudger underneath to release the plastic clips.
  6. BlackBerry Curve 8310 Trackball Replacement: étape 6, image 1 de 3 BlackBerry Curve 8310 Trackball Replacement: étape 6, image 2 de 3 BlackBerry Curve 8310 Trackball Replacement: étape 6, image 3 de 3
    • Be careful not to damage the front cover's plastic clips while trying to separate it from the phone.
    • Use a spudger to pry the front cover away from the side panels.
    • Work the spudger around the entire phone until the front cover is free.
  7. BlackBerry Curve 8310 Trackball Replacement, Keyboard: étape 7, image 1 de 1
    • Remove the keyboard.
  8. BlackBerry Curve 8310 Trackball Replacement, Trackball: étape 8, image 1 de 1
    • Use a spudger to pry off the plastic ring surrounding the trackball.
  9. BlackBerry Curve 8310 Trackball Replacement: étape 9, image 1 de 2 BlackBerry Curve 8310 Trackball Replacement: étape 9, image 2 de 2
    • Remove the trackball from the phone.
Sean Willis
Membre depuis le 01/26/12
229 Réputation
5 tutoriels rédigés
Équipe
Cal Poly, Team 10-32, Amido Winter 2012 Membre de l'équipe Cal Poly, Team 10-32, Amido Winter 2012
CPSU-AMIDO-W12S10G32
4 membres
8 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 25
Total : 3,798
