Aller au contenu principal
BlackBerry Curve 8900 Keypad Replacement
Ce dont vous avez besoin
  1. BlackBerry Curve 8900 Keypad Replacement, Remove the battery: étape 1, image 1 de 1
    • Remove the back cover and the battery from the device.
  2. BlackBerry Curve 8900 Keypad Replacement, Remove the protective cover: étape 2, image 1 de 1
    • 4 screws should be visible. Pry off the lower portion of the back to reveal all 6 screws.
  3. BlackBerry Curve 8900 Keypad Replacement, Remove the screws from the midframe: étape 3, image 1 de 1
    • Remove all six T6 screws from the midframe.
  4. BlackBerry Curve 8900 Keypad Replacement, Split apart the device: étape 4, image 1 de 1
    • Separate the midframe from the rest of the device.
  5. BlackBerry Curve 8900 Keypad Replacement, Remove the motherboard: étape 5, image 1 de 1
    • Gently pry back the plastic tabs that secure the motherboard to the case.
    • Slowly work your way around the case prying the tabs until the motherboard comes free.
    • Remove the motherboard.
    • The keypad and navigation ball may become loose and fall away from the motherboard.
  6. BlackBerry Curve 8900 Keypad Replacement, Remove the keypad: étape 6, image 1 de 3 BlackBerry Curve 8900 Keypad Replacement, Remove the keypad: étape 6, image 2 de 3 BlackBerry Curve 8900 Keypad Replacement, Remove the keypad: étape 6, image 3 de 3
    • Lift the keypad from the motherboard.
    • When replacing the keypad, be sure that the navigation ball is in its original position.
3 autres ont terminé cette réparation.
Renae Bishop
Membre depuis le 09/07/11
68 Réputation
4 tutoriels rédigés
Équipe
Cuesta, Team 1-3, Zipperian Fall 2011 Membre de l'équipe Cuesta, Team 1-3, Zipperian Fall 2011
CUESTA-ZIPPERIAN-F11S1G3
3 membres
8 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 2
30 derniers jours : 3
Total : 6,983
