Aller au contenu principal
BlackBerry Curve 8900 Microphone Replacement
Ce dont vous avez besoin
  1. BlackBerry Curve 8900 Microphone Replacement, Microphone: étape 1, image 1 de 1
    • Press and slide the battery cover from the back of the device with your fingers.
    • Remove the battery by pulling it out.
    • The battery is shown outside of the device on the right side of the photograph, "BlackBerry D-X18."
  2. BlackBerry Curve 8900 Microphone Replacement: étape 2, image 1 de 1
    Outil utilisé dans cette étape :
    iFixit Opening Tool
    $1.99
    J'achète
    • Using the iFixit Opening Tool, remove the lower rear cover.
  3. BlackBerry Curve 8900 Microphone Replacement: étape 3, image 1 de 1
    T6 Torx Screwdriver
    $9.99
    J'achète
  4. BlackBerry Curve 8900 Microphone Replacement: étape 4, image 1 de 1
    iFixit Opening Tool
    $1.99
    J'achète
  5. BlackBerry Curve 8900 Microphone Replacement: étape 5, image 1 de 2 BlackBerry Curve 8900 Microphone Replacement: étape 5, image 2 de 2
    • Work your way around the case, slowly, prying the back of the plastic tabs until the motherboard comes free.
  6. BlackBerry Curve 8900 Microphone Replacement: étape 6, image 1 de 1
    • With your fingers, carefully remove the screen so as not to damage it.
  7. BlackBerry Curve 8900 Microphone Replacement: étape 7, image 1 de 2 BlackBerry Curve 8900 Microphone Replacement: étape 7, image 2 de 2
    • With your fingers, carefully unhook the antenna cable in all three locations.
  8. BlackBerry Curve 8900 Microphone Replacement: étape 8, image 1 de 1
    Spudger
    $3.99
    J'achète
    • Detach the ribbon cable on the front of the motherboard using the Spudger tool.
  9. BlackBerry Curve 8900 Microphone Replacement: étape 9, image 1 de 1
    • Detach the motherboard from both ribbon connections.
    • The ribbon connections are indicated by red circles on the photograph.
    • The ribbon connections are indicated by orange rectangles on the photograph.
  10. BlackBerry Curve 8900 Microphone Replacement: étape 10, image 1 de 2 BlackBerry Curve 8900 Microphone Replacement: étape 10, image 2 de 2
    • Replace the entire motherboard to replace the microphone.
Johnny Tran
Membre depuis le 09/10/11
473 Réputation
4 tutoriels rédigés
Équipe
Cuesta, Team 1-3, Zipperian Fall 2011 Membre de l'équipe Cuesta, Team 1-3, Zipperian Fall 2011
CUESTA-ZIPPERIAN-F11S1G3
3 membres
8 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 1
30 derniers jours : 3
Total : 4,440
