Introduction
This guide details the removal of the rear, bottom and side covers; the frame, motherboard and front cover; and the keypad and trackball of the Blackberry Pearl 8100.
Pièces
Aucune pièce nécessaire.
Push the button indicated by the yellow marker to remove the rear cover.
  • Push the button indicated by the yellow marker to remove the rear cover.
  • Remove the battery (not pictured).
Ajouter un commentaire
Use a T6 Torx screwdriver to remove the two screws indicated by the yellow markers.
  • Use a T6 Torx screwdriver to remove the two screws indicated by the yellow markers.
Use the plastic opening tool to loosen the bottom cover, and then remove the bottom cover from the cellphone. Use the plastic opening tool to loosen the bottom cover, and then remove the bottom cover from the cellphone.
  • Use the plastic opening tool to loosen the bottom cover, and then remove the bottom cover from the cellphone.
Use the plastic opening tool to remove the side covers. The side covers are attached to the cell phone with small plastic snaps. These snaps can be bent or broken easily.
  • Use the plastic opening tool to remove the side covers.
  • The side covers are attached to the cell phone with small plastic snaps. These snaps can be bent or broken easily.
With the bottom and side covers removed, the two screws indicated by yellow markers will be visible.
  • With the bottom and side covers removed, the two screws indicated by yellow markers will be visible.
  • Use the T6 Torx screwdriver to remove the screws.
With the screws removed, the frame can be detached. With the screws removed, the frame can be detached.
  • With the screws removed, the frame can be detached.
Use the plastic opening tool to separate the motherboard from the front cover. While removing the motherboard, the button that opens the rear cover may come loose along with a small spring. Do not lose these.
  • Use the plastic opening tool to separate the motherboard from the front cover.
  • While removing the motherboard, the button that opens the rear cover may come loose along with a small spring. Do not lose these.
Separate the keypad (first picture) and trackball (second picture) from the front cover. Lift the piece of plastic that overlays the trackball (second picture). The trackball should then come loose.
  • Separate the keypad (first picture) and trackball (second picture) from the front cover.
  • Lift the piece of plastic that overlays the trackball (second picture). The trackball should then come loose.
  • Keep the trackball intact. The trackball has extremely small magnetic bolts underneath that are difficult to reassemble.
These are all the parts of the BlackBerry Pearl 8100 completely disassembled. From left to right, the parts are as follows: rear cover, front cover, motherboard, side covers, trackball, keypad, bottom cover, and frame.
  • These are all the parts of the BlackBerry Pearl 8100 completely disassembled. From left to right, the parts are as follows: rear cover, front cover, motherboard, side covers, trackball, keypad, bottom cover, and frame.
Justin
Membre depuis le 06/10/2014
132 Réputation
2 tutoriels rédigés
Équipe
Aristotle Membre de l'équipe Aristotle
Community
5 membres
2 tutoriels rédigés
Voir les statistiques:
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 4
Total : 256
