Aller au contenu principal
BlackBerry Z10 Screen Replacement
Ce dont vous avez besoin
  1. BlackBerry Z10 Screen Replacement, Battery: étape 1, image 1 de 1
    • Turn the phone over so that the back cover faces up.
    • Locate the groove at the bottom center of the phone.
    • Press the groove with your thumb to release the edge of the case from the phone.
  2. BlackBerry Z10 Screen Replacement: étape 2, image 1 de 2 BlackBerry Z10 Screen Replacement: étape 2, image 2 de 2
    • Use your thumb and index finger to carefully open the sides of the phone.
    • Start from the bottom and work your fingers up along the sides of the phone until the back cover is completely separated from the body of the phone.
  3. BlackBerry Z10 Screen Replacement: étape 3, image 1 de 3 BlackBerry Z10 Screen Replacement: étape 3, image 2 de 3 BlackBerry Z10 Screen Replacement: étape 3, image 3 de 3
    • Lift the bottom corner of the battery with your fingers.
    • Remove the battery from the body of the phone.
  4. BlackBerry Z10 Screen Replacement, Screen: étape 4, image 1 de 1
    • Use a T3 or T4 (sub-models vary) Torx screwdriver to remove the nine screws shown in the picture.
    • Keep the screws in a safe place.
  5. BlackBerry Z10 Screen Replacement: étape 5, image 1 de 3 BlackBerry Z10 Screen Replacement: étape 5, image 2 de 3 BlackBerry Z10 Screen Replacement: étape 5, image 3 de 3
    • Gently lift the plastic housing off the phone and set it aside. You can now see the motherboard.
  6. BlackBerry Z10 Screen Replacement: étape 6, image 1 de 3 BlackBerry Z10 Screen Replacement: étape 6, image 2 de 3 BlackBerry Z10 Screen Replacement: étape 6, image 3 de 3
    • Use the spudger to detach the green flat-top connector located under the rear camera. Slowly push the connector up and back. Refer to the first and second images.
    • Use the spudger to detach and lift the orange flat-top connector seen in the second image. Slowly push the connector up and back.
    • Then, detach the remaining three flat-top connectors one at a time to release the motherboard from the housing. The third connector is hidden underneath the largest one.
  7. BlackBerry Z10 Screen Replacement: étape 7, image 1 de 3 BlackBerry Z10 Screen Replacement: étape 7, image 2 de 3 BlackBerry Z10 Screen Replacement: étape 7, image 3 de 3
    • The motherboard is fragile. Make sure all connectors have been detached before you remove the motherboard.
    • Carefully remove the motherboard and set it aside on an antistatic surface.
    • Depending on the part you bought, you may be able to skip the remaining steps. A complete screen and case assembly can be purchased together. If that's what you have, simply move the motherboard to the new piece and reverse the steps above to reassemble your device. Otherwise, continue with the steps below.
  8. BlackBerry Z10 Screen Replacement: étape 8, image 1 de 3 BlackBerry Z10 Screen Replacement: étape 8, image 2 de 3 BlackBerry Z10 Screen Replacement: étape 8, image 3 de 3
    • The screen is fragile and may crack if the screws are not removed carefully.
    • Use a T2 Torx screwdriver to remove the first small screw located at the top right. Refer to the second image.
    • Then unscrew the four screws that surround the case. Refer to the third image.
    • Keep all five screws in a safe place.
  9. BlackBerry Z10 Screen Replacement: étape 9, image 1 de 3 BlackBerry Z10 Screen Replacement: étape 9, image 2 de 3 BlackBerry Z10 Screen Replacement: étape 9, image 3 de 3
    • Turn the phone over so that the touch screen faces you.
    • Slide a plastic opening tool around the rectangular edge of the phone to separate the touch screen from the case. Start from either of the bottom corners and work your way around the phone to loosen the screen.
    • The connectors are connected to the phone case. Be careful not to damage them when you separate the screen from the phone case.
    • Gently separate the screen from the phone case. Now, the phone is ready for a new screen.
30 autres ont terminé cette réparation.
Emie Lou Cruz
Membre depuis le 09/08/14
1 084 Réputation
3 tutoriels rédigés
Équipe
CSU Fullerton, Team 1-2, Bruce Fall 2014 Membre de l'équipe CSU Fullerton, Team 1-2, Bruce Fall 2014
CSUF-BRUCE-F14S1G2
3 membres
4 tutoriels rédigés
7 commentaires
In the Tools list is a T4 Screwdriver and in Step 4 you write T3 Torx. Wich is the right one and for what kind of Z10 is it (STL100-2, STL100-3, etc.) ?
Stefan Schenk - Réponse
Torx bits increase in diameter with increases in size and it is very possible to have a driver one size smaller than the head and still drive the screw. You will know you have the correct exact Torx driver for the head you are using when it fits perfectly without any slack. Also, there would be no benefit to them changing screw head sizes during production as all the parts are manufactured with that head in mind. I swapped my screen with a T1 and a T3. However, the looseness of the T3 driver in the screw head that I encountered is a strong indication of the correct size actually being a T4. The T1 wasnt as loose but it WAS loose so I would not be surprised if the smaller heads WERE officially sized as T2. So as long as you have at least a T1 & a T3, you are good to go but a T2 & a T4 is just as good a combination for this fix.
Mian Atif - Réponse
T2 sent from iFixit didn't loosen the T2 screws on the Z10. Had to pull out a pocket knife and stick the pointed end of the blade into the screw and loosen it a bit before the T2 screw driver would work.
John Nguyen - Réponse
What was the MPN of the replacement screen you ordered? I too have a RFF91LW and need to replace my screen.
markjennraconsulting - Réponse
where can i buy replacement screen?
rakeshkota - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 6
30 derniers jours : 30
Total : 37,749
