Introduction
For removing and replacing the Blackberry 7520 battery, follow this guide.
Outils
Aucun outil requis.
Pièces
Aucune pièce nécessaire.
Turn the phone upside down. Push down on the black button on the back of the phone to slide the rear panel off.
  • Turn the phone upside down.
  • Push down on the black button on the back of the phone to slide the rear panel off.
  • The battery should be visible now.
Ajouter un commentaire
Hold the BlackBerry in one hand face-up with the screen facing towards you. Gently smack the phone against your hand to dislodge the battery. Gently smack the phone against your hand to dislodge the battery.
  • Hold the BlackBerry in one hand face-up with the screen facing towards you.
  • Gently smack the phone against your hand to dislodge the battery.
Kits RAM pour Mac
Accélérez votre Mac. Maximisez sa mémoire.
Kits RAM pour Mac
Augmentez la mémoire de votre Mac.
To install the battery turn the phone on its back. Line the battery in place where the gold connectors (red circle) line up with the gold pins (blue circle) Once the battery is lined up push the battery in and down until it is locked in.
  • To install the battery turn the phone on its back.
  • Line the battery in place where the gold connectors (red circle) line up with the gold pins (blue circle)
  • Once the battery is lined up push the battery in and down until it is locked in.
Once the battery has been put back in, line the the black button (red circle) of the panel up with its socket (blue circle) in the BlackBerry phone. Push the panel inwards then down until it locks in.
  • Once the battery has been put back in, line the the black button (red circle) of the panel up with its socket (blue circle) in the BlackBerry phone.
  • Push the panel inwards then down until it locks in.
  • Once the panel is in you have successfully changed your battery!
Ligne d'arrivée
Nathan
Membre depuis le 18/01/2010
31 Réputation
7 tutoriels rédigés
Équipe
Cal Poly, Team 5-7, Forte Winter 2010 Membre de l'équipe Cal Poly, Team 5-7, Forte Winter 2010
CPSU-FORTE-W10S5G7
5 membres
7 tutoriels rédigés
Voir les statistiques:
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 0
Total : 1,423
