Aller au contenu principal
Blackberry 7520 LCD Screen Replacement
Ce dont vous avez besoin
  1. Blackberry 7520 LCD Screen Replacement, Battery: étape 1, image 1 de 2 Blackberry 7520 LCD Screen Replacement, Battery: étape 1, image 2 de 2
    • Turn the phone upside down.
    • Push down on the black button on the back of the phone to slide the rear panel off.
    • The battery should be visible now.
  2. Blackberry 7520 LCD Screen Replacement: étape 2, image 1 de 3 Blackberry 7520 LCD Screen Replacement: étape 2, image 2 de 3 Blackberry 7520 LCD Screen Replacement: étape 2, image 3 de 3
    • Hold the BlackBerry in one hand face-up with the screen facing towards you.
    • Gently smack the phone against your hand to dislodge the battery.
  3. Blackberry 7520 LCD Screen Replacement, Motherboard: étape 3, image 1 de 2 Blackberry 7520 LCD Screen Replacement, Motherboard: étape 3, image 2 de 2
    • Use a T6 Torx screwdriver to remove the 6 screws holding the rear of the phone.
  4. Blackberry 7520 LCD Screen Replacement: étape 4, image 1 de 2 Blackberry 7520 LCD Screen Replacement: étape 4, image 2 de 2
    • Use a pick or plastic opening tool to push the clips holding the rear away from you.
    • Applying too much pressure could break the plastic clips and permanently damage your Blackberry.
  5. Blackberry 7520 LCD Screen Replacement: étape 5, image 1 de 1
    • Repeat the process of unlatching the clips for the top section of the Blackberry.
  6. Blackberry 7520 LCD Screen Replacement: étape 6, image 1 de 2 Blackberry 7520 LCD Screen Replacement: étape 6, image 2 de 2
    • Slide the rear panel forward to reveal the motherboard.
  7. Blackberry 7520 LCD Screen Replacement: étape 7, image 1 de 2 Blackberry 7520 LCD Screen Replacement: étape 7, image 2 de 2
    • Remove the indicated screws using a T6 Torx screwdriver.
  8. Blackberry 7520 LCD Screen Replacement: étape 8, image 1 de 2 Blackberry 7520 LCD Screen Replacement: étape 8, image 2 de 2
    • Remove the motherboard.
    • Remove the indicated screw using the T6 Torx screwdriver.
  9. Blackberry 7520 LCD Screen Replacement: étape 9, image 1 de 2 Blackberry 7520 LCD Screen Replacement: étape 9, image 2 de 2
    • Pull the metal plate away from the front panel of the cell phone.
  10. Blackberry 7520 LCD Screen Replacement: étape 10, image 1 de 1
    • Place the faceplate face-down and the interior of the phone face-up, as shown.
  11. Blackberry 7520 LCD Screen Replacement, LCD Screen: étape 11, image 1 de 1
    • Turn the phone so that it faces towards you.
  12. Blackberry 7520 LCD Screen Replacement: étape 12, image 1 de 1
    • Use a pick or other small tool to pop the small plastic clip holding the LCD panel on
  13. Blackberry 7520 LCD Screen Replacement: étape 13, image 1 de 2 Blackberry 7520 LCD Screen Replacement: étape 13, image 2 de 2
    • Pull the LCD screen off of the board.
Nathan
Membre depuis le 01/18/10
31 Réputation
6 tutoriels rédigés
Équipe
Cal Poly, Team 5-7, Forte Winter 2010 Membre de l'équipe Cal Poly, Team 5-7, Forte Winter 2010
CPSU-FORTE-W10S5G7
5 membres
9 tutoriels rédigés
Un commentaire
It’s too bad that iFixit didn’t post a teardown listing the parts for the BlackBerry 7520, since so little is known about its parts.
amosbatto - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 1
30 derniers jours : 3
Total : 1,432
