Introduction
Disassembling the logic board in the rear of the Blackberry allows you to get to the LCD screen and keypad.
Pièces
Aucune pièce nécessaire.
Turn the phone upside down. Push down on the black button on the back of the phone to slide the rear panel off.
  • Turn the phone upside down.
  • Push down on the black button on the back of the phone to slide the rear panel off.
  • The battery should be visible now.
Ajouter un commentaire
Hold the BlackBerry in one hand face-up with the screen facing towards you. Gently smack the phone against your hand to dislodge the battery. Gently smack the phone against your hand to dislodge the battery.
  • Hold the BlackBerry in one hand face-up with the screen facing towards you.
  • Gently smack the phone against your hand to dislodge the battery.
Use a T6 Torx screwdriver to remove the 6 screws holding the rear of the phone. Use a T6 Torx screwdriver to remove the 6 screws holding the rear of the phone.
  • Use a T6 Torx screwdriver to remove the 6 screws holding the rear of the phone.
Use a pick or small tool to push the clips holding the rear away from you. Applying too much pressure could break the plastic clips and permanently damage your Blackberry.
  • Use a pick or small tool to push the clips holding the rear away from you.
  • Applying too much pressure could break the plastic clips and permanently damage your Blackberry.
Kits RAM pour Mac
Accélérez votre Mac. Maximisez sa mémoire.
Kits RAM pour Mac
Augmentez la mémoire de votre Mac.
Repeat the process of unlatching the clips for the top section of the Blackberry.
  • Repeat the process of unlatching the clips for the top section of the Blackberry.
Slide the rear panel forward to reveal the logic board. Slide the rear panel forward to reveal the logic board.
  • Slide the rear panel forward to reveal the logic board.
Remove the indicated screws using a T6 Torx screwdriver. Remove the indicated screws using a T6 Torx screwdriver.
  • Remove the indicated screws using a T6 Torx screwdriver.
Remove the logic board. Remove the indicated screw using the T6 Torx screwdriver.
  • Remove the logic board.
  • Remove the indicated screw using the T6 Torx screwdriver.
Pull the metal plate away from the front panel of the cell phone. Pull the metal plate away from the front panel of the cell phone.
  • Pull the metal plate away from the front panel of the cell phone.
Place the faceplate face-down and the interior of the phone face-up, as shown.
  • Place the faceplate face-down and the interior of the phone face-up, as shown.
Nathan
Membre depuis le 18/01/2010
31 Réputation
7 tutoriels rédigés
Équipe
Cal Poly, Team 5-7, Forte Winter 2010 Membre de l'équipe Cal Poly, Team 5-7, Forte Winter 2010
CPSU-FORTE-W10S5G7
5 membres
7 tutoriels rédigés
Voir les statistiques:
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 1
Total : 3,348
