Aller au contenu principal
Blackberry Bold 9000 Trackball Replacement
Ce dont vous avez besoin
  1. Blackberry Bold 9000 Trackball Replacement, Battery: étape 1, image 1 de 1
    • Place your Blackberry facedown in front of you.
  2. Blackberry Bold 9000 Trackball Replacement: étape 2, image 1 de 1
    • Press the cover release button on the bottom of your device. Lift and remove the back cover.
  3. Blackberry Bold 9000 Trackball Replacement: étape 3, image 1 de 1
    • From the top, use your fingernail to lift the battery out.
  4. Blackberry Bold 9000 Trackball Replacement, Rear Case: étape 4, image 1 de 1
    • Remove the SIM card.
  5. Blackberry Bold 9000 Trackball Replacement: étape 5, image 1 de 1
    • Remove the six 7.0mm Torx screws securing the rear case to the rest of the phone.
  6. Blackberry Bold 9000 Trackball Replacement: étape 6, image 1 de 1
    • Use the plastic opening tool to remove the rear case.
  7. Blackberry Bold 9000 Trackball Replacement, Trackball: étape 7, image 1 de 1
    • Using the same plastic opening tool, lift out the motherboard assembly.
    • Remove the motherboard assembly from left to right, using caution near the audio jack on the right side of the device.
  8. Blackberry Bold 9000 Trackball Replacement: étape 8, image 1 de 1
    • Using a spudger, pry the top of the metal casing off. There are two pins holding it in place; it should pop off easily.
    • Repeat to the bottom.
    • This step requires pristine dexterity. Try to find a friend with smaller fingers if necessary.
  9. Blackberry Bold 9000 Trackball Replacement: étape 9, image 1 de 1
    • Lift the trackball out of its socket.
5 autres ont terminé cette réparation.
Kelly
Membre depuis le 01/18/12
566 Réputation
6 tutoriels rédigés
Équipe
Cal Poly, Team 8-17, Maness Winter 2012 Membre de l'équipe Cal Poly, Team 8-17, Maness Winter 2012
CPSU-MANESS-W12S8G17
4 membres
7 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 5
7 derniers jours : 11
30 derniers jours : 21
Total : 11,187
