Aller au contenu principal
Blackberry Bold 9000 Volume Toggle Replacement
Ce dont vous avez besoin
  1. Blackberry Bold 9000 Volume Toggle Replacement, Battery: étape 1, image 1 de 1
    • Place your Blackberry facedown in front of you.
  2. Blackberry Bold 9000 Volume Toggle Replacement: étape 2, image 1 de 1
    • Press the cover release button on the bottom of your device. Lift and remove the back cover.
  3. Blackberry Bold 9000 Volume Toggle Replacement: étape 3, image 1 de 1
    • From the top, use your fingernail to lift the battery out.
  4. Blackberry Bold 9000 Volume Toggle Replacement, Rear Case: étape 4, image 1 de 1
    • Remove the SIM card.
  5. Blackberry Bold 9000 Volume Toggle Replacement: étape 5, image 1 de 1
    • Remove the six 7.0mm Torx screws securing the rear case to the rest of the phone.
  6. Blackberry Bold 9000 Volume Toggle Replacement: étape 6, image 1 de 1
    • Use the plastic opening tool to remove the rear case.
  7. Blackberry Bold 9000 Volume Toggle Replacement, Volume Toggle: étape 7, image 1 de 1
    • Lift out the motherboard assembly using the plastic opening tool, prying at all four sides of the device.
    • Try to remove from left to right, using caution with the audio jack on the right side of the device.
  8. Blackberry Bold 9000 Volume Toggle Replacement: étape 8, image 1 de 1
    • Locate the volume toggle on the main frame of the phone.
    • Using the spudger, push the toggle in from the outside and remove.
  9. Blackberry Bold 9000 Volume Toggle Replacement: étape 9, image 1 de 1
    • Place the new toggle in, using the pointed end of the spudger to attach the toggle to the upper and lower pins.
    • Make sure the toggle is completely in place by pressing it outward into the frame.
2 autres ont terminé cette réparation.
Kelly
Membre depuis le 01/18/12
566 Réputation
6 tutoriels rédigés
Équipe
Cal Poly, Team 8-17, Maness Winter 2012 Membre de l'équipe Cal Poly, Team 8-17, Maness Winter 2012
CPSU-MANESS-W12S8G17
4 membres
7 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 2
Total : 2,442
