Aller au contenu principal
Blackberry Bold 9900 Trackpad Replacement
Ce dont vous avez besoin
  1. Blackberry Bold 9900 Trackpad Replacement, Battery: étape 1, image 1 de 1
    • Place phone screen down.
    • Use your finger to life upward on the battery case.
    • Pull the cover away from the battery.
  2. Blackberry Bold 9900 Trackpad Replacement: étape 2, image 1 de 1
    • Lift the edge of battery with the green stripe upward to remove battery.
  3. Blackberry Bold 9900 Trackpad Replacement, MicroSD card: étape 3, image 1 de 2 Blackberry Bold 9900 Trackpad Replacement, MicroSD card: étape 3, image 2 de 2
    • The MicroSD card is located where the red rectangle is shown.
    • To remove MicroSD card, push the card inward towards the top of the phone then release. The MicroSD card will be ejected.
  4. Blackberry Bold 9900 Trackpad Replacement, Keyboard: étape 4, image 1 de 2 Blackberry Bold 9900 Trackpad Replacement, Keyboard: étape 4, image 2 de 2
    • Lift the bezel at the bottom of the phone up and peel it away from the phone.
  5. Blackberry Bold 9900 Trackpad Replacement: étape 5, image 1 de 2 Blackberry Bold 9900 Trackpad Replacement: étape 5, image 2 de 2
    • Remove the two exposed screws using the T5 Torx screwdriver.
  6. Blackberry Bold 9900 Trackpad Replacement: étape 6, image 1 de 1
    • Now lever the keyboard up using the screwdriver in the indicated hole.
  7. Blackberry Bold 9900 Trackpad Replacement: étape 7, image 1 de 2 Blackberry Bold 9900 Trackpad Replacement: étape 7, image 2 de 2
    • The keyboard is attached via a ribbon cable. Pull the cable up to remove the keyboard.
  8. Blackberry Bold 9900 Trackpad Replacement, Trackpad: étape 8, image 1 de 3 Blackberry Bold 9900 Trackpad Replacement, Trackpad: étape 8, image 2 de 3 Blackberry Bold 9900 Trackpad Replacement, Trackpad: étape 8, image 3 de 3
    • Push into the trackpad. This will release the trackpad supporting piece.
  9. Blackberry Bold 9900 Trackpad Replacement: étape 9, image 1 de 2 Blackberry Bold 9900 Trackpad Replacement: étape 9, image 2 de 2
    • The trackpad is attached via ribbon cable. Pull this cable up in order to release the trackpad.
Chris Velasquez
Membre depuis le 01/30/18
214 Réputation
2 tutoriels rédigés
Équipe
Baylor, Team S1-G4, Johnson Spring 2018 Membre de l'équipe Baylor, Team S1-G4, Johnson Spring 2018
BU-JOHNSON-S18S1G4
3 membres
6 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 7
30 derniers jours : 19
Total : 1,034
