Introduction
This guide will help you properly remove the back case of the phone. It is a simple and easy two step process.
In order to remove the back case, start by flipping the phone to the back side and look at it from the top.
Place your finger in the small notch on the left side of the charging port (facing from the back).
Once your finger is in the notch, pull the back case towards yourself to remove it.
To reassemble your device, insert the two tabs located at the bottom of the cover into the indents at the bottom of the phone. Then, press down on all sides of the phone until you hear it snap into place.
