Introduction
These steps will outlines replacement of the QC25 Motherboard, one of which is located in each earpiece. Be warned, this guide requires precision soldering of very small components and not recommended for the faint of heart.
Begin repair by removing the ear cushion.
  • Begin repair by removing the ear cushion.
  • The cushion is held on by a few small plastic clips. Pry carefully with plastic opening tool or fingernails.
Ajouter un commentaire
Next, remove the soft lining behind the cushion. This is held on with adhesive and is easily removed by hand.
  • Next, remove the soft lining behind the cushion. This is held on with adhesive and is easily removed by hand.
Once the soft lining is removed from behind the ear cushion, two screws will be exposed. Carefully remove the two 5 mm screws with a precision screwdriver (PH00) and put aside. Carefully remove the two 5 mm screws with a precision screwdriver (PH00) and put aside.
  • Once the soft lining is removed from behind the ear cushion, two screws will be exposed.
  • Carefully remove the two 5 mm screws with a precision screwdriver (PH00) and put aside.
Kits de RAM Mac
Accélérez votre Mac. Maximisez sa mémoire.
Kits de RAM Mac
Obtenez plus de mémoire sur votre Mac.
Flip the earphones back over and carefully pry around the outside cover of the earpiece.
  • Flip the earphones back over and carefully pry around the outside cover of the earpiece.
  • Try a plastic opening tool before moving on to harder metal tools.
  • This cover will come loose with moderate pressure.
There are 3 screws holding the motherboard to the earpiece. Remove these screws to make the next step easier. Remove these screws to make the next step easier.
  • There are 3 screws holding the motherboard to the earpiece.
  • Remove these screws to make the next step easier.
Once the motherboard is exposed, all of the soldered connection will need to be removed.
  • Once the motherboard is exposed, all of the soldered connection will need to be removed.
  • Be careful of this step and take note of the position of each wire.
  • This should only be attempted by someone with experience soldering small components, as irreparable damage may be result from improper methods. For help with this step see this guide on Comment souder et dessouder des connexions
After removing all the soldered joints, the motherboard can be removed by hand.
  • After removing all the soldered joints, the motherboard can be removed by hand.
  • The connections will all need to be re-soldered into their respective locations.
Samuel Coss
Membre depuis le 26/03/2018
195 Réputation
1 tutoriel rédigé
Équipe
IUPUI, Team S2-G3, Harley Spring 2018 Membre de l'équipe IUPUI, Team S2-G3, Harley Spring 2018
IUPUI-HARLEY-S18S2G3
3 membres
2 tutoriels rédigés
Voir les statistiques:
Dernières 24 heures : 3
7 derniers jours : 32
30 derniers jours : 136
Total : 167
