Aller au contenu principal
Bose Soundlink II Battery Replacement
Ce dont vous avez besoin
  1. Bose Soundlink II Battery Replacement, Bose Soundlink II Cover Removal: étape 1, image 1 de 1
    • Using a 2.5 mm hex wrench, remove the two 13 mm screws from the bottom of the speaker.
  2. Bose Soundlink II Battery Replacement: étape 2, image 1 de 1
    • Push up on the back of the cover until it slides up slightly.
    • Pull the cover up and away from the speaker backing.
  3. Bose Soundlink II Battery Replacement, Battery: étape 3, image 1 de 1
    • Using the screwdriver with the T-10 star tip, remove the 6.75 mm. screws marked in red.
  4. Bose Soundlink II Battery Replacement: étape 4, image 1 de 2 Bose Soundlink II Battery Replacement: étape 4, image 2 de 2
    • Carefully remove the battery by pulling it out of the speaker.
14 autres ont terminé cette réparation.
Kevin Bailey
Membre depuis le 09/24/15
464 Réputation
2 tutoriels rédigés
Équipe
Texas Tech, Team 22-4, Rauch Fall 2015 Membre de l'équipe Texas Tech, Team 22-4, Rauch Fall 2015
TTU-RAUCH-F15S22G4
3 membres
3 tutoriels rédigés
11 commentaires
Where i can buy one them battery model?
Daniel Campos - Réponse
Just ordered a “Used, in good shape”, and it seems to be, however, it’s the REALLY original model, with the solid flap on the front, that turns into the stand. SN: 054867920870604AE. Guessing this is NOT the “Soundlink II”, but the original model. Instructions that came with it claim battery will last up to 3 hours. JUST IN CASE this battery is shot, was looking into what’s involved to replace it. However, mine being older, wondering if this battery would still fit?
      Thanks, Bob.
bobveitch4 - Réponse
How do I get a used replacement battery for this in Nigeria? Please contact me on johnpaulokenyodo@gmail.com if any. Thanks
Okenyodo Johnpaul - Réponse
I bought an Replacement battery which brand is Emaks from Amazon and do it following the guide,It works well now!Thank you!!!
Emily - Réponse
How much the battery only
Joboy De Guzman II - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 4
7 derniers jours : 63
30 derniers jours : 232
Total : 32,091
