Aller au contenu principal
Bose Soundlink III Battery Replacement
Ce dont vous avez besoin
  1. Bose Soundlink III Battery Replacement, Battery: étape 1, image 1 de 1
    • Use a spudger to pry the rubber pads off of the bottom panel of the SoundLink.
    • The rubber pads should have enough adhesive to stick when you reassemble them at the end. If not, however, you may need your own adhesive.
  2. Bose Soundlink III Battery Replacement: étape 2, image 1 de 2 Bose Soundlink III Battery Replacement: étape 2, image 2 de 2
    • Remove the two 12.5 mm screws using a Phillips #2 screwdriver.
    • These screws may be difficult to remove. If necessary, use a lever for extra torque.
    • Remove the bottom panel.
  3. Bose Soundlink III Battery Replacement: étape 3, image 1 de 1
    • Flip the rear panel back to allow access to the SoundLink's battery.
  4. Bose Soundlink III Battery Replacement: étape 4, image 1 de 2 Bose Soundlink III Battery Replacement: étape 4, image 2 de 2
    • Remove the two 12.5 mm Phillips #2 screws from the sides of the battery.
38 autres ont terminé cette réparation.
Dakoda Sanders
Membre depuis le 02/04/16
1 540 Réputation
4 tutoriels rédigés
Équipe
USF Tampa, Team 3-2, Wollert Spring 2016 Membre de l'équipe USF Tampa, Team 3-2, Wollert Spring 2016
USFT-WOLLERT-S16S3G2
4 membres
7 tutoriels rédigés
25 commentaires
Hello, I wonder where I could buy a raplacement battery for my Bose Soundlink III. (I'm from Belgium)
Thanks for the response.
Gabriel Lohest - Réponse
Gabriel, ik heb Bose gecontacteerd en ze zeggen dat ze dat niet apart verkopen. Het enigste wat ik heb gevonden is dit:http://www.ecrater.com/p/25268626/batter...
Of als het nog onder garantie valt, gewoon terug opsturen.
Gabrial, I've contacted Bose and they say that they didn't sell them seperately. The only thing that I've found is this:http://www.ecrater.com/p/25268626/batter...
If it still falls under warranty, send the speaker back.
JJ Hu - Réponse
yea i'm also interested to buy bose soundlink 3 battery hurmmm where could i get it....
Admin Fluffy - Réponse
Yes please, where do you get replacement batteries (I'm from Australia and Bose here want to charge me $149 to remove and replace 4 screws!)
Bob Mandassa - Réponse
I want to buy also. I'm here in Saudi arabia dammam
alphamendoza5 - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 8
7 derniers jours : 98
30 derniers jours : 400
Total : 58,144
