Aller au contenu principal
Bose Soundlink Revolve Bottom Circuit Board Replacement
Ce dont vous avez besoin
  1. Bose Soundlink Revolve Bottom Circuit Board Replacement, Bottom Circuit Board Access: étape 1, image 1 de 2 Bose Soundlink Revolve Bottom Circuit Board Replacement, Bottom Circuit Board Access: étape 1, image 2 de 2
    • Flip speaker over so that the bottom is facing up.
    • Using the blue spudger, lift the gray foam up and slowly peel it off with your hand.
  2. Bose Soundlink Revolve Bottom Circuit Board Replacement: étape 2, image 1 de 3 Bose Soundlink Revolve Bottom Circuit Board Replacement: étape 2, image 2 de 3 Bose Soundlink Revolve Bottom Circuit Board Replacement: étape 2, image 3 de 3
    • Using the screwdriver, unscrew three screws.
    • Detach the bottom cover from the rest of the speaker by pulling the two in opposite directions.
  3. Bose Soundlink Revolve Bottom Circuit Board Replacement: étape 3, image 1 de 2 Bose Soundlink Revolve Bottom Circuit Board Replacement: étape 3, image 2 de 2
    • Remove the screw that is above the charging port.
  4. Bose Soundlink Revolve Bottom Circuit Board Replacement: étape 4, image 1 de 2 Bose Soundlink Revolve Bottom Circuit Board Replacement: étape 4, image 2 de 2
    • Remove the two screws connecting the motherboard to the bottom cover of the speaker.
    • Remove the bottom cover.
  5. Bose Soundlink Revolve Bottom Circuit Board Replacement, AUX/USB Port: étape 5, image 1 de 3 Bose Soundlink Revolve Bottom Circuit Board Replacement, AUX/USB Port: étape 5, image 2 de 3 Bose Soundlink Revolve Bottom Circuit Board Replacement, AUX/USB Port: étape 5, image 3 de 3
    • Using the blue plastic opening tool, pry up the small black clamp connecting the AUX/USB port to the lower circuit board.
    • Remove the AUX/USB port from the device.
  6. Bose Soundlink Revolve Bottom Circuit Board Replacement, Bottom Circuit Board: étape 6, image 1 de 1
    • Remove the yellow tape over the location where the ribbon from the central speaker meets the bottom circuit board.
    • Use the blue plastic opening tool to pry up the black latch holding down the ribbon.
    • Remove the motherboard from the device.
5 autres ont terminé cette réparation.
Brian Butner
Membre depuis le 09/27/17
804 Réputation
3 tutoriels rédigés
Équipe
USF Tampa, Team S6-G2, Remmell Fall 2017 Membre de l'équipe USF Tampa, Team S6-G2, Remmell Fall 2017
USFT-REMMELL-F17S6G2
4 membres
4 tutoriels rédigés
42 commentaires
I need the ribbon because it is damage, can you sell one to me?
My email is ttegil@hotmail.com can you send me the way I can buy it.
Kind regards
Gilberto - Réponse
Hello do toi fond thé ribbon because i have thé same problème .
M'y email adresse thualromain44.rt@gmail.com
Thanks you
romain thual -
Hi I need bottom circuit board for bose revolve , could you sale it for me. mail: seawolf1974@mail.ru , delivery to Spain
kindly regards
seawolf1974 - Réponse
I need bottom circuit board for Bose revolve, can I get it available in Nigeria, @sullivaniheme@gmail.com
Sullivan - Réponse
Hey there, I also require the bottom circuit board for my Bose Revolve sam.rowlands@hotmail.com
Sam - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 5
7 derniers jours : 28
30 derniers jours : 119
Total : 13,938
