Introduction
A damaged or disconnected motherboard can lead to potential component or entire device failure. One can reference this guide to learn how to successfully remove and replace the motherboard found within the device.
Pièces
Aucune pièce nécessaire.
To remove the outer casing, use a 3mm Hex bit to remove the 4 large 12mm Hex screws on both sides of the device.
  • To remove the outer casing, use a 3mm Hex bit to remove the 4 large 12mm Hex screws on both sides of the device.
Ajouter un commentaire
Using the Metal Spudger, carefully pry  each side of the rubber casing away from the device.
  • Using the Metal Spudger, carefully pry each side of the rubber casing away from the device.
  • A little resistance should be felt, but not enough to bend the spudger.
To remove the inner plastic casing, use a Phillips #00 head bit to remove the 16 small 9mm screws surrounding the top side of the device.
  • To remove the inner plastic casing, use a Phillips #00 head bit to remove the 16 small 9mm screws surrounding the top side of the device.
Idées cadeaux pour la Fête des Pères
Mettons nos papas à l’honneur ainsi que nos mentors qui nous ont appris à réparer.
Honorons ceux qui nous ont enseigné à réparer.
Carefully lift away the housing and replace the broken casing/component. Replace using the new casing.
  • Carefully lift away the housing and replace the broken casing/component. Replace using the new casing.
To remove the motherboard, proceed to unscrew the 3 Phillips #00 bit type, 13mm long screws located on both sides of the motherboard.
  • To remove the motherboard, proceed to unscrew the 3 Phillips #00 bit type, 13mm long screws located on both sides of the motherboard.
Then, proceed to unscrew the 5 Phillips #00 bit type, 9mm long screws located on the face of the charging dock.
  • Then, proceed to unscrew the 5 Phillips #00 bit type, 9mm long screws located on the face of the charging dock.
Disconnect the two 4-pin auxiliary button register cables connected on both sides of the motherboard.
  • Disconnect the two 4-pin auxiliary button register cables connected on both sides of the motherboard.
Once disconnected, carefully remove the motherboard by pulling upwards.
  • Once disconnected, carefully remove the motherboard by pulling upwards.
Erik Oliva
Membre depuis le 14/02/2018
607 Réputation
6 tutoriels rédigés
Équipe
USF Tampa, Team S2-G1, Eyestone Spring 2018 Membre de l'équipe USF Tampa, Team S2-G1, Eyestone Spring 2018
USFT-EYESTONE-S18S2G1
4 membres
6 tutoriels rédigés
Voir les statistiques:
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 6
Total : 23
