Aller au contenu principal
Braven BRV-1M Sub-woofer Cone Replacement
Ce dont vous avez besoin
  1. Braven BRV-1M Sub-woofer Cone Replacement, Sub-woofer Cone: étape 1, image 1 de 1
    • To remove the outer rubber casing use a 3mm Hex bit to remove the 4 large 12mm Hex screws on both sides, found on the bottom part of the device.
  2. Braven BRV-1M Sub-woofer Cone Replacement: étape 2, image 1 de 1
    • Using the Metal Spudger, carefully pry each side of the rubber casing away from the device.
    • A little resistance should be felt, but not enough to bend the spudger.
  3. Braven BRV-1M Sub-woofer Cone Replacement: étape 3, image 1 de 1
    • To remove the hard inner plastic casing, use a Phillips #00 head bit to remove the 16 small 9mm screws surrounding the subwoofer on the top side of the device.
  4. Braven BRV-1M Sub-woofer Cone Replacement: étape 4, image 1 de 1
    • Carefully lift away the broken sub-woofer plate of the device. Replace with functioning sub-woofer plate.
Erik Oliva
Membre depuis le 02/14/18
607 Réputation
6 tutoriels rédigés
Équipe
USF Tampa, Team S2-G1, Eyestone Spring 2018 Membre de l'équipe USF Tampa, Team S2-G1, Eyestone Spring 2018
USFT-EYESTONE-S18S2G1
4 membres
6 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 3
Total : 171
