Introduction
Replacing the heating tank should it fail to work.
Use a Phillips #0 screwdriver to remove the following ten screws: Four 18mm Phillips screws. Four 9.75mm Phillips screws.
  • Use a Phillips #0 screwdriver to remove the following ten screws:
    • Four 18mm Phillips screws.
    • Four 9.75mm Phillips screws.
    • Two 8mm Phillips screws.
    • The cover will not remove entirely. Keep green ground wire attached to the cover.
Ajouter un commentaire
Remove the two 14.5 Phillips screws. Ensure that only the water inlet valve can be moved.
  • Remove the two 14.5 Phillips screws.
  • Ensure that only the water inlet valve can be moved.
Use a Phillips #0 screwdriver to remove the following six screws: Six 14.5mm Phillips screws.
  • Use a Phillips #0 screwdriver to remove the following six screws:
    • Six 14.5mm Phillips screws.
Remove the power cord from the groove. (the black cord that leads into the green wire.) This creates more slack in the wire to give you more room to work with.
    • Remove the power cord from the groove. (the black cord that leads into the green wire.)
    • This creates more slack in the wire to give you more room to work with.
    • DO NOT remove green wire from the cover its attached to.
Identify the hose that connects to the heating tank. (Observe that it is held up on a small hook.) Push down on the hook and carefully move the hose from its grip.
    • Identify the hose that connects to the heating tank. (Observe that it is held up on a small hook.)
    • Push down on the hook and carefully move the hose from its grip.
Carefully pull out the heating tank by hand.
    • Carefully pull out the heating tank by hand.
    • The heating tank may still be hot. Exercise caution when grabbing hold of the tank. If necessary, wait four to six hours after last use.
    • Reminder for reassembly; You will need a new band to tie the hose back to the heating tank.
2 autre(s) ont terminé cette réparation.
Antonio
Membre depuis le 26/09/2012
73 Réputation
6 tutoriels rédigés
Équipe
Cal Poly, Team 1-3, Propen Fall 2012 Membre de l'équipe Cal Poly, Team 1-3, Propen Fall 2012
CPSU-PROPEN-F12S1G3
4 membres
6 tutoriels rédigés
Voir les statistiques:
Dernières 24 heures : 0
7 derniers jours : 2
30 derniers jours : 22
Total : 3,282
