Aller au contenu principal
Brightsign 4k Heat Sink Replacement
Ce dont vous avez besoin
  1. Brightsign 4k Heat Sink Replacement, Outer Shell: étape 1, image 1 de 3 Brightsign 4k Heat Sink Replacement, Outer Shell: étape 1, image 2 de 3 Brightsign 4k Heat Sink Replacement, Outer Shell: étape 1, image 3 de 3
    • Remove three 8mm screws from the left side of the device.
    • Remove four 8mm screws from the right side of the device.
  2. Brightsign 4k Heat Sink Replacement: étape 2, image 1 de 3 Brightsign 4k Heat Sink Replacement: étape 2, image 2 de 3 Brightsign 4k Heat Sink Replacement: étape 2, image 3 de 3
    • Apply pressure on the SD card to pop it out of the port.
    • Remove the card by pulling it out.
  3. Brightsign 4k Heat Sink Replacement: étape 3, image 1 de 3 Brightsign 4k Heat Sink Replacement: étape 3, image 2 de 3 Brightsign 4k Heat Sink Replacement: étape 3, image 3 de 3
    • Press down on the top cover of the device and slid it towards you until you see a slight gap created.
    • Lift the top cover off.
  4. Brightsign 4k Heat Sink Replacement: étape 4, image 1 de 3 Brightsign 4k Heat Sink Replacement: étape 4, image 2 de 3 Brightsign 4k Heat Sink Replacement: étape 4, image 3 de 3
    • Slide the body case back away from the bottom.
    • Pull up the body case to remove it from the bottom.
  5. Brightsign 4k Heat Sink Replacement, Motherboard Removal: étape 5, image 1 de 2 Brightsign 4k Heat Sink Replacement, Motherboard Removal: étape 5, image 2 de 2
    • Remove the four 8mm screws at each corner of the motherboard with a JIS #0 screwdriver.
  6. Brightsign 4k Heat Sink Replacement: étape 6, image 1 de 2 Brightsign 4k Heat Sink Replacement: étape 6, image 2 de 2
    • Lift the motherboard out of the casing.
  7. Brightsign 4k Heat Sink Replacement, Heat Sink: étape 7, image 1 de 2 Brightsign 4k Heat Sink Replacement, Heat Sink: étape 7, image 2 de 2
    • Flip the motherboard upside down.
  8. Brightsign 4k Heat Sink Replacement: étape 8, image 1 de 3 Brightsign 4k Heat Sink Replacement: étape 8, image 2 de 3 Brightsign 4k Heat Sink Replacement: étape 8, image 3 de 3
    • Remove the black adhesive that covers the four screws.
    • Remove the four screws.
    • Flip the motherboard over and remove the heat sink by pulling up.
Mattison Collins
Membre depuis le 02/15/18
85 Réputation
1 tutoriel rédigé
Équipe
USF Tampa, Team S17-G6, Boczar Spring 2018 Membre de l'équipe USF Tampa, Team S17-G6, Boczar Spring 2018
USFT-BOCZAR-S18S17G6
4 membres
6 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 3
7 derniers jours : 8
30 derniers jours : 10
Total : 224
