Introduction
This guide will take you through the process of properly removing the motherboard of the device. Removal of the motherboard is necessary to access additional components that may need fixing.
Pièces
Aucune pièce nécessaire.
Remove three 8mm screws from the left side of the device. Remove four 8mm screws from the right side of the device. Remove four 8mm screws from the right side of the device.
  • Remove three 8mm screws from the left side of the device.
  • Remove four 8mm screws from the right side of the device.
Ajouter un commentaire
Apply pressure on the SD card to pop it out of the port. Remove the card by pulling it out. Remove the card by pulling it out.
  • Apply pressure on the SD card to pop it out of the port.
  • Remove the card by pulling it out.
Mac RAM Kits
Speed up your Mac. Max out its memory.
Mac RAM Kits
Get more memory out of your Mac.
Press down on the top cover of the device and slid it towards you until you see a slight gap created. Lift the top cover off. Lift the top cover off.
  • Press down on the top cover of the device and slid it towards you until you see a slight gap created.
  • Lift the top cover off.
Slide the body case back away from the bottom. Pull up the body case to remove it from the bottom. Pull up the body case to remove it from the bottom.
  • Slide the body case back away from the bottom.
  • Pull up the body case to remove it from the bottom.
Remove the four 8mm screws at each corner of the motherboard with a JIS #0 screwdriver. Remove the four 8mm screws at each corner of the motherboard with a JIS #0 screwdriver.
  • Remove the four 8mm screws at each corner of the motherboard with a JIS #0 screwdriver.
Lift the motherboard out of the casing. Lift the motherboard out of the casing.
  • Lift the motherboard out of the casing.
Zackery
Membre depuis le 15/02/2018
323 Réputation
2 tutoriels rédigés
Équipe
USF Tampa, Team S17-G6, Boczar Spring 2018 Membre de l'équipe USF Tampa, Team S17-G6, Boczar Spring 2018
USFT-BOCZAR-S18S17G6
4 membres
6 tutoriels rédigés
Voir les statistiques:
Dernières 24 heures : 0
7 derniers jours : 1
30 derniers jours : 10
Total : 68
