Introduction
In this guide, you will see why your Brother PT-1290 isn't powering up correctly or at all.
First, flip over your label maker and push down on the top part(by the face plate) and push on the circle part with ridges. Next open the label maker carefully to prevent any damage. First, flip over your label maker and push down on the top part(by the face plate) and push on the circle part with ridges. Next open the label maker carefully to prevent any damage. First, flip over your label maker and push down on the top part(by the face plate) and push on the circle part with ridges. Next open the label maker carefully to prevent any damage.
  • First, flip over your label maker and push down on the top part(by the face plate) and push on the circle part with ridges. Next open the label maker carefully to prevent any damage.
Ajouter un commentaire
Once the label maker is open, remove the six AAA drained batteries.
  • Once the label maker is open, remove the six AAA drained batteries.
  • If your using an AC adapter, replace the old one with the new HQRP adapter.
  • If you see white on the batteries, that would be corrosion. Be careful when disposing.
Now place in the new six AAA batteries. Make sure the batteries are correctly in and touching the golden prongs. Make sure the batteries are correctly in and touching the golden prongs.
  • Now place in the new six AAA batteries.
  • Make sure the batteries are correctly in and touching the golden prongs.
Lorraine Canez
Membre depuis le 25/10/2014
301 Réputation
3 tutoriels rédigés
Équipe
Gateway, Team 1-4, Johnson Fall 2014 Membre de l'équipe Gateway, Team 1-4, Johnson Fall 2014
GCC-JOHNSON-F14S1G4
3 membres
6 tutoriels rédigés
Voir les statistiques:
Dernières 24 heures : 0
7 derniers jours : 2
30 derniers jours : 9
Total : 294
