Introduction
This guide will take you through the broken/damaged keyboard to the P-Touch step by step.
Turn the device to it's side toward the bottom of the keyboard. Then pop open the case and remove the batteries. Turn the device to it's side toward the bottom of the keyboard. Then pop open the case and remove the batteries. Turn the device to it's side toward the bottom of the keyboard. Then pop open the case and remove the batteries.
  • Turn the device to it's side toward the bottom of the keyboard. Then pop open the case and remove the batteries.
Ajouter un commentaire
Remove back of device and set aside. Remove back of device and set aside. Remove back of device and set aside.
  • Remove back of device and set aside.
Remove all 1/4 inch screws(6 total) with a (+PH00) screwdriver. Open slowly not to damage the display data cable. Remove all 1/4 inch screws(6 total) with a (+PH00) screwdriver. Open slowly not to damage the display data cable. Remove all 1/4 inch screws(6 total) with a (+PH00) screwdriver. Open slowly not to damage the display data cable.
  • Remove all 1/4 inch screws(6 total) with a (+PH00) screwdriver. Open slowly not to damage the display data cable.
Use a plastic opening tool to remove the flat-panel membrane keyboard. Lift up and set aside. Use a plastic opening tool to remove the flat-panel membrane keyboard. Lift up and set aside. Use a plastic opening tool to remove the flat-panel membrane keyboard. Lift up and set aside.
  • Use a plastic opening tool to remove the flat-panel membrane keyboard. Lift up and set aside.
Use a spudger to aid in removing the keyboard. Gently lift out while removing the LCD screen that is connected to the data cable and finishing removing. Gently lift out while removing the LCD screen that is connected to the data cable and finishing removing.
  • Use a spudger to aid in removing the keyboard.
  • Gently lift out while removing the LCD screen that is connected to the data cable and finishing removing.
Angela Araujo
Membre depuis le 24/10/2014
101 Réputation
1 tutoriel rédigé
Équipe
Gateway, Team 1-4, Johnson Fall 2014 Membre de l'équipe Gateway, Team 1-4, Johnson Fall 2014
GCC-JOHNSON-F14S1G4
3 membres
6 tutoriels rédigés
Voir les statistiques:
Dernières 24 heures : 0
7 derniers jours : 2
30 derniers jours : 3
Total : 161
