Introduction
This guide will walk you through the process of replacing a dull or broken cutter blade on a Brother PT-D200.
Open the back panel of the device by pressing down on and then pulling the indication arrows on the top center of the cover upward towards you. Open the back panel of the device by pressing down on and then pulling the indication arrows on the top center of the cover upward towards you.
  • Open the back panel of the device by pressing down on and then pulling the indication arrows on the top center of the cover upward towards you.
Ajouter un commentaire
Locate the cutter blade unit (mint green) as shown in the picture.
  • Locate the cutter blade unit (mint green) as shown in the picture.
Using the thumb and forefinger, pull up, applying a moderate amount of pressure until the cutter blade unit loosens and is removed. The blade is sharp.
  • Using the thumb and forefinger, pull up, applying a moderate amount of pressure until the cutter blade unit loosens and is removed.
  • The blade is sharp.
Blaire McCreary
Membre depuis le 24/01/2014
201 Réputation
2 tutoriels rédigés
Équipe
Cal Poly, Team 13-16, Regan Winter 2014 Membre de l'équipe Cal Poly, Team 13-16, Regan Winter 2014
CPSU-REGAN-W14S13G16
4 membres
9 tutoriels rédigés
Voir les statistiques:
Dernières 24 heures : 0
7 derniers jours : 4
30 derniers jours : 18
Total : 969
