Aller au contenu principal
Brother PT-D200 Faceplate Replacement
Ce dont vous avez besoin
  1. Brother PT-D200 Faceplate Replacement, Battery: étape 1, image 1 de 1
    • Flip the device over and press down on the indication arrows located at the top center of the back cover and pull it open.
  2. Brother PT-D200 Faceplate Replacement: étape 2, image 1 de 1
    • Remove the six AAA batteries.
  3. Brother PT-D200 Faceplate Replacement, Back of Device: étape 3, image 1 de 1
    • Use the Helping Hand 1/4" screwdriver to unscrew the six 3/16" corner screws.
  4. Brother PT-D200 Faceplate Replacement: étape 4, image 1 de 1
    • Close the back cover and then flip the device over and separate the top half from the bottom half as shown.
    • Be gentle when lifting the top of the device, there is a ribbon cable attaching the two halves together.
  5. Brother PT-D200 Faceplate Replacement, Circuit Board Cables: étape 5, image 1 de 1
    • Gently pull out the ribbon cable from the circuit board.
    • The ribbon cable is very fragile.
  6. Brother PT-D200 Faceplate Replacement: étape 6, image 1 de 1
    • Remove two-pin plastic connector from the circuit board.
    • Gently pull the two-pin connector from the circuit board to avoid damaging the board.
  7. Brother PT-D200 Faceplate Replacement, Face Plate: étape 7, image 1 de 1
    • On the top portion of the device there are four grey clips locking the faceplate in place. The two top clips are circled in the image. The two others are located in the other corners of the device.
  8. Brother PT-D200 Faceplate Replacement: étape 8, image 1 de 2 Brother PT-D200 Faceplate Replacement: étape 8, image 2 de 2
    • Pull the clips inward two at a time, first the top then the bottom, to snap the face plate off.
[deleted]
Membre depuis le 01/24/14
301 Réputation
3 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 2
30 derniers jours : 5
Total : 644
