Aller au contenu principal
Bush Pump Above Grade Riser Pipe Replacement
Ce dont vous avez besoin
  1. Bush Pump Above Grade Riser Pipe Replacement, Head and Handle: étape 1, image 1 de 2 Bush Pump Above Grade Riser Pipe Replacement, Head and Handle: étape 1, image 2 de 2
    • Test pump performance by pumping 40 strokes.
    • An effective pump should return at least 10 liters.
  2. Bush Pump Above Grade Riser Pipe Replacement: étape 2, image 1 de 2 Bush Pump Above Grade Riser Pipe Replacement: étape 2, image 2 de 2
    • Remove the two pins connecting the handle to the slider.
  3. Bush Pump Above Grade Riser Pipe Replacement: étape 3, image 1 de 2 Bush Pump Above Grade Riser Pipe Replacement: étape 3, image 2 de 2
    • Pull the two lever arms away from the slider.
  4. Bush Pump Above Grade Riser Pipe Replacement: étape 4, image 1 de 2 Bush Pump Above Grade Riser Pipe Replacement: étape 4, image 2 de 2
    • Lift the two pins attaching the pump frame to the head and handle up, off of the pump frame.
  5. Bush Pump Above Grade Riser Pipe Replacement: étape 5, image 1 de 3 Bush Pump Above Grade Riser Pipe Replacement: étape 5, image 2 de 3 Bush Pump Above Grade Riser Pipe Replacement: étape 5, image 3 de 3
    • Throughout this step, make sure you support the handle and head with at least three hands.
    • Slide the bearing rod out of the head.
    • Inspect the bearing rod and head for any wear or tear.
  6. Bush Pump Above Grade Riser Pipe Replacement: étape 6, image 1 de 1
    • Remove the head and handle, and place them on a clean surface to prevent contamination.
  7. Bush Pump Above Grade Riser Pipe Replacement, Riser Main Slider: étape 7, image 1 de 2 Bush Pump Above Grade Riser Pipe Replacement, Riser Main Slider: étape 7, image 2 de 2
    • Firmly lift the riser main slider with two hands.
    • Use caution not to drop the riser main, as this can damage the pump cylinder.
  8. Bush Pump Above Grade Riser Pipe Replacement: étape 8, image 1 de 3 Bush Pump Above Grade Riser Pipe Replacement: étape 8, image 2 de 3 Bush Pump Above Grade Riser Pipe Replacement: étape 8, image 3 de 3
    • Use a pipe wrench to fully loosen the above grade riser pipe.
  9. Bush Pump Above Grade Riser Pipe Replacement: étape 9, image 1 de 3 Bush Pump Above Grade Riser Pipe Replacement: étape 9, image 2 de 3 Bush Pump Above Grade Riser Pipe Replacement: étape 9, image 3 de 3
    • Lift the slider and riser main pipe.
    • Place a pump rod clamp around the rod, and tighten it securely against the pump rod.
    • Carefully lower the riser main and slider to allow it to rest on the rod clamp.
  10. Bush Pump Above Grade Riser Pipe Replacement: étape 10, image 1 de 3 Bush Pump Above Grade Riser Pipe Replacement: étape 10, image 2 de 3 Bush Pump Above Grade Riser Pipe Replacement: étape 10, image 3 de 3
    • Loosen and remove both the pump rod jam nut and pump rod nut on the top of the slider.
  11. Bush Pump Above Grade Riser Pipe Replacement: étape 11, image 1 de 2 Bush Pump Above Grade Riser Pipe Replacement: étape 11, image 2 de 2
    • Remove the riser main slider, and inspect it for wear and tear.
    • Set the slider in a sanitary place to prevent contamination.
  12. Bush Pump Above Grade Riser Pipe Replacement, Above Grade Riser Pipe: étape 12, image 1 de 3 Bush Pump Above Grade Riser Pipe Replacement, Above Grade Riser Pipe: étape 12, image 2 de 3 Bush Pump Above Grade Riser Pipe Replacement, Above Grade Riser Pipe: étape 12, image 3 de 3
    • Remove the above grade riser pipe.
    • Firmly screw a T-handle onto the pump rod.
    • If you are replacing the above ground riser main, leave the T-handle attached until you are ready to install the replacement part.
2 autres ont terminé cette réparation.
Jake Devincenzi
Membre depuis le 04/18/11
117 325 Réputation
57 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 5
30 derniers jours : 20
Total : 436
