Introduction
Cooling can become an issue for your computer when the fan is not able to get the job done, it can be slow or broken entirely. This guide will help you replace the slow or stopped fan to help reduce the temperatures in your computer.
Remove the header by pulling on it with two fingers. Remove the header by pulling on it with two fingers.
  • Remove the header by pulling on it with two fingers.
Ajouter un commentaire
Kits RAM pour Mac
Accélérez votre Mac. Maximisez sa mémoire.
Kits RAM pour Mac
Augmentez la mémoire de votre Mac.
Remove the six 2.5mm screws using a Phillips #1 screwdriver.
  • Remove the six 2.5mm screws using a Phillips #1 screwdriver.
Remove the fan by moving it to the side and lifting it out of the computer.
  • Remove the fan by moving it to the side and lifting it out of the computer.
Armani Tayeh
Membre depuis le 19/03/2018
411 Réputation
4 tutoriels rédigés
Équipe
UMass Dartmouth, Team S3-G2, Peak Spring 2018 Membre de l'équipe UMass Dartmouth, Team S3-G2, Peak Spring 2018
UMASSD-PEAK-S18S3G2
3 membres
9 tutoriels rédigés
Voir les statistiques:
Dernières 24 heures : 1
7 derniers jours : 3
30 derniers jours : 7
Total : 19
