Aller au contenu principal
Cambridge Audio A3i Power Cord and Transformer Replacement
Ce dont vous avez besoin
  1. Cambridge Audio A3i Power Cord and Transformer Replacement, Case: étape 1, image 1 de 1
    • Remove 2 screws from each side of the amplifier.
  2. Cambridge Audio A3i Power Cord and Transformer Replacement: étape 2, image 1 de 1
    • Remove 2 screws on rear of device. Slide top cover up and back from main case.
  3. Cambridge Audio A3i Power Cord and Transformer Replacement: étape 3, image 1 de 2 Cambridge Audio A3i Power Cord and Transformer Replacement: étape 3, image 2 de 2
    • Remove 3 screws on bottom of case.
    • Remove 13 screws on rear panel.
    • Do not move the rear panel too far, as the power cord is still connected.
  4. Cambridge Audio A3i Power Cord and Transformer Replacement: étape 4, image 1 de 1
    • Using a pair of pliers, squeeze the retainer for the power cord as shown and pull it toward the external side the panel.
    • It may require some wiggling, but it should slip out of the hole and then off of the cord.
  5. Cambridge Audio A3i Power Cord and Transformer Replacement, Power Cord and Transformer: étape 5, image 1 de 1
    • Carefully de-solder ends of power cord from circuit board.
    • Keep track of the colors of the cords. The brown cord leads to the L on the circuit board, and this cord will lead to a fuse in the power plug. The blue cord leads to the N on the board.
    • Finally, pull the power cord through the rear panel to completely remove it.
  6. Cambridge Audio A3i Power Cord and Transformer Replacement: étape 6, image 1 de 1
    • To remove the transformer the motherboard must be removed. This is to gain access to the solder on the power cords. -See guide for removing motherboard.
    • Remove the 4 nuts holding down the transformer bracket using a 7mm nut driver or socket.
5 autres ont terminé cette réparation.
Colby
Membre depuis le 04/15/10
338 Réputation
3 tutoriels rédigés
Équipe
Cal Poly, Team 28-36, Regan Spring 2010 Membre de l'équipe Cal Poly, Team 28-36, Regan Spring 2010
CPSU-REGAN-S10S28G36
4 membres
3 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 6
30 derniers jours : 19
Total : 7,128
