Introduction
When removing the on/off switch of the compressor, you will first need to remove the shroud. The trick to removing the on/off switch is on the underside of the shroud. This is discussed in the guide.
Outils
Pièces
Aucune pièce nécessaire.
Unscrew the four 1cm long shroud screws using a 6mm Allen Wrench. Unscrew the four 1cm long shroud screws using a 6mm Allen Wrench. Unscrew the four 1cm long shroud screws using a 6mm Allen Wrench.
  • Unscrew the four 1cm long shroud screws using a 6mm Allen Wrench.
Ajouter un commentaire
Remove the plastic shroud from the compressor. Do not pull the shroud too far from the compressor. You could damage the on/off switch wiring.
  • Remove the plastic shroud from the compressor.
  • Do not pull the shroud too far from the compressor. You could damage the on/off switch wiring.
Gently pull the wire attached from the pressure switch to the on/off switch.
  • Gently pull the wire attached from the pressure switch to the on/off switch.
  • It should come off the pressure switch with ease.
  • Make sure you are pulling the correct wire. The pressure switch could be in a different configuration on your compressor than in the picture.
Gently pull the wire connected from the on/off switch to the motor of the compressor.
  • Gently pull the wire connected from the on/off switch to the motor of the compressor.
  • It should be the only wire keeping the shroud from being lifted from the compressor.
Twist the On/Off switch from the underside of the shroud. Twist 90 degrees in any direction or until the on/off switch prongs are in a vertical position.
  • Twist the On/Off switch from the underside of the shroud.
  • Twist 90 degrees in any direction or until the on/off switch prongs are in a vertical position.
  • When the switch has reached the correct position, you will feel it "click" into place.
Push the on/off switch from the underside of the shroud until it comes loose.
  • Push the on/off switch from the underside of the shroud until it comes loose.
  • If the switch is not in the correct position highlighted in the previous step, it will not be easily removed and could damage the shroud.
Caleb Davies
Membre depuis le 07/10/2014
501 Réputation
4 tutoriels rédigés
Équipe
Cal Poly, Team 14-29, Maness Fall 2014 Membre de l'équipe Cal Poly, Team 14-29, Maness Fall 2014
CPSU-MANESS-F14S14G29
4 membres
7 tutoriels rédigés
Voir les statistiques:
Dernières 24 heures : 0
7 derniers jours : 4
30 derniers jours : 16
Total : 675
