Introduction
In order to complete this repair properly, you will need teflon tape to seal the threads of the safety valve. Although this step seems unnecessary in some cases, it will make your compressor run more efficiently without excessive starting and stopping. The replacement of safety switch is straightforward.
Outils
Pièces
Aucune pièce nécessaire.
Using the medium crescent wrench, unscrew the safety valve by twisting it counter-clockwise.
  • Using the medium crescent wrench, unscrew the safety valve by twisting it counter-clockwise.
  • The safety valve may be difficult to unscrew because of corrosion.
Ajouter un commentaire
Apply teflon tape to the replacement safety valve.
  • Apply teflon tape to the replacement safety valve.
  • The teflon tape should be wound tightly around the entire threaded portion of the safety valve.
Eric
Membre depuis le 09/10/2014
387 Réputation
3 tutoriels rédigés
Équipe
Cal Poly, Team 14-29, Maness Fall 2014 Membre de l'équipe Cal Poly, Team 14-29, Maness Fall 2014
CPSU-MANESS-F14S14G29
4 membres
7 tutoriels rédigés
Voir les statistiques:
Dernières 24 heures : 1
7 derniers jours : 1
30 derniers jours : 2
Total : 226
