Introduction
This guide will show you how to access, remove, and replace the LCD screen. The process is safe and uncomplicated.
Pièces
Aucune pièce nécessaire.
Remove the two 4.8 mm black screws above the lens on the front of the camera.
  • Remove the two 4.8 mm black screws above the lens on the front of the camera.
Ajouter un commentaire
Remove the 4.3 mm black screw under the lens ring, and the 4.8 mm black screw under the camera.
  • Remove the 4.3 mm black screw under the lens ring, and the 4.8 mm black screw under the camera.
Remove the 4.8 mm black screw on the left side of the camera.
  • Remove the 4.8 mm black screw on the left side of the camera.
Remove the front panel by lifting it away from the camera's body.
  • Remove the front panel by lifting it away from the camera's body.
Slide the outer eyepiece upward to remove it.
  • Slide the outer eyepiece upward to remove it.
Remove the two 4.75 mm black screws located  on the top of the camera.
  • Remove the two 4.75 mm black screws located on the top of the camera.
Remove the four 4.3 mm  black screws near the bottom corners of the eyepiece at the back of the camera.
  • Remove the four 4.3 mm black screws near the bottom corners of the eyepiece at the back of the camera.
Slowly separate the top panel from the camera by pushing it upward. Separating the top panel too far or quickly can damage the ribbon cable and connecting wires that are still attached to the top panel of the camera.
  • Slowly separate the top panel from the camera by pushing it upward.
  • Separating the top panel too far or quickly can damage the ribbon cable and connecting wires that are still attached to the top panel of the camera.
To unclip gold connector push the edge up and away from the lcd screen. A plastic opening tool is recommended.
  • To unclip gold connector push the edge up and away from the lcd screen. A plastic opening tool is recommended.
  • The gold connector can fall into the camera, but it will remain attached and can be pulled back up.
Lift LCD screen out of mount.
  • Lift LCD screen out of mount.
Sterling Vinson
Membre depuis le 17/04/2011
216 Réputation
5 tutoriels rédigés
Équipe
Cal Poly, Team 8-8, Regan Spring 2011 Membre de l'équipe Cal Poly, Team 8-8, Regan Spring 2011
CPSU-REGAN-S11S8G8
5 membres
11 tutoriels rédigés
Thank's , your tutorial nice ... gracias
fajar - Réponse
Where do you find replacement lcd screen if the one on the camera is cracked?
Jasmine - Réponse
Voir les statistiques:
Dernières 24 heures : 1
7 derniers jours : 5
30 derniers jours : 10
Total : 4,508
