Introduction
This guide will help you step by step to reach and replace the inner eyepiece of canon EOS 30.
Pièces
Aucune pièce nécessaire.
Remove the two 4.8 mm black screws above the lens on the front of the camera.
  • Remove the two 4.8 mm black screws above the lens on the front of the camera.
Ajouter un commentaire
Remove the 4.3 mm black screw under the lens ring, and the 4.8 mm black screw under the camera.
  • Remove the 4.3 mm black screw under the lens ring, and the 4.8 mm black screw under the camera.
Remove the 4.8 mm black screw on the left side of the camera.
  • Remove the 4.8 mm black screw on the left side of the camera.
Remove the front panel by lifting it away from the camera's body.
  • Remove the front panel by lifting it away from the camera's body.
Slide the outer eyepiece upward to remove it.
  • Slide the outer eyepiece upward to remove it.
Remove the two 4.75 mm black screws located  on the top of the camera.
  • Remove the two 4.75 mm black screws located on the top of the camera.
Remove the four 4.3 mm  black screws near the bottom corners of the eyepiece at the back of the camera.
  • Remove the four 4.3 mm black screws near the bottom corners of the eyepiece at the back of the camera.
Slowly separate the top panel from the camera by pushing it upward. Separating the top panel too far or quickly can damage the ribbon cable and connecting wires that are still attached to the top panel of the camera.
  • Slowly separate the top panel from the camera by pushing it upward.
  • Separating the top panel too far or quickly can damage the ribbon cable and connecting wires that are still attached to the top panel of the camera.
Remove the two 9.5 mm black screws that attach the inner eyepiece to the camera's body and remove the eyepiece.
  • Remove the two 9.5 mm black screws that attach the inner eyepiece to the camera's body and remove the eyepiece.
Remove the two 4.3 mm silver screws on each side of the inner eyepiece.
  • Remove the two 4.3 mm silver screws on each side of the inner eyepiece.
Separate the inner eyepiece into three parts.
  • Separate the inner eyepiece into three parts.
  • The outer piece (left) has a small gear, which can easily fall off and get lost.
Remove the two 3.6 mm black screws from the outer piece.
  • Remove the two 3.6 mm black screws from the outer piece.
Remove the glass panel and replace it.
  • Remove the glass panel and replace it.
  • When removing the glass panel make sure not to separate the small rubber piece attached around the frame.
3 autre(s) ont terminé cette réparation.
Jackie
Membre depuis le 17/04/2011
218 Réputation
3 tutoriels rédigés
Équipe
Cal Poly, Team 8-8, Regan Spring 2011 Membre de l'équipe Cal Poly, Team 8-8, Regan Spring 2011
CPSU-REGAN-S11S8G8
5 membres
11 tutoriels rédigés
Voir les statistiques:
Dernières 24 heures : 0
7 derniers jours : 1
30 derniers jours : 9
Total : 2,326
