Introduction
This guide shows you how to install the front panel of your camera.
Pièces
Aucune pièce nécessaire.
Using a #00 Phillips screw driver, remove three 4.4 mm Phillips screws as indicated by the red circles.
  • Using a #00 Phillips screw driver, remove three 4.4 mm Phillips screws as indicated by the red circles.
Ajouter un commentaire
Using your finger, peel back the textured grip so the components are separated. Using your finger, peel back the textured grip so the components are separated.
  • Using your finger, peel back the textured grip so the components are separated.
Using the flat end of a spudger, loosen the connection between the front panel and the device. Remove the front panel using your hands. Remove the front panel using your hands.
  • Using the flat end of a spudger, loosen the connection between the front panel and the device.
  • Remove the front panel using your hands.
Kyle Reis
Membre depuis le 02/04/2012
49 Réputation
4 tutoriels rédigés
Équipe
Cal Poly, Team 14-9, Forte Spring 2012 Membre de l'équipe Cal Poly, Team 14-9, Forte Spring 2012
CPSU-FORTE-S12S14G9
5 membres
12 tutoriels rédigés
Voir les statistiques:
Dernières 24 heures : 0
7 derniers jours : 1
30 derniers jours : 3
Total : 666
