Introduction
This guide details how to replace the flash bulb of this camera.
Locate the battery cover at the bottom of the camera.
  • Locate the battery cover at the bottom of the camera.
  • Pull down on the black tab to open the cover.
Ajouter un commentaire
Push the grey tab on the right side of the battery.
  • Push the grey tab on the right side of the battery.
  • Remove the battery from the slot.
come on , i m very happy
JACK - Réponse
Using the Phillips screwdriver, unscrew the two 4.9mm Phillips head screws which are located underneath the flash.
  • Using the Phillips screwdriver, unscrew the two 4.9mm Phillips head screws which are located underneath the flash.
Remove the covering.
  • Remove the covering.
Use the tweezers to remove the excess glue around the wiring. This will allow you to cut the wire and remove the light in the next step.
  • Use the tweezers to remove the excess glue around the wiring. This will allow you to cut the wire and remove the light in the next step.
Use the wire cutters to cut the wiring connected to the flash.
  • Use the wire cutters to cut the wiring connected to the flash.
5 autre(s) ont terminé cette réparation.
Jordan Rabold
Membre depuis le 14/04/2014
607 Réputation
4 tutoriels rédigés
Équipe
Cal Poly, Team 12-33, Maness Spring 2014 Membre de l'équipe Cal Poly, Team 12-33, Maness Spring 2014
CPSU-MANESS-S14S12G33
4 membres
7 tutoriels rédigés
how do you reverse step 6 - cutting the wires?
jeremyyoung - Réponse
You dont tell how to make sure capacitors are discharged before changing the flash ? and do you know what is the replacement number of the flash bulb itself ?
jackqc09 - Réponse
No parts required? So I can repair my flash not having to buy a new bulb? haha Please, I need the link from where I repair my burned built-in flash :/
gustavoaleme - Réponse
Voir les statistiques:
Dernières 24 heures : 3
7 derniers jours : 10
30 derniers jours : 37
Total : 2,582
