Introduction
Using these instructions, we'll make it easy and simple for you to replace the LCD in your Canon camera.
Pièces
Aucune pièce nécessaire.
Locate the battery cover at the bottom of the camera.
  • Locate the battery cover at the bottom of the camera.
  • Pull down on the black tab to open the cover.
Ajouter un commentaire
Push the grey tab on the right side of the battery.
  • Push the grey tab on the right side of the battery.
  • Remove the battery from the slot.
come on , i m very happy
JACK - Réponse
Remove the six screws on the housing of the LCD. Four 3.1mm Phillips screws on the side with the hinge. Two 2.7mm Phillips screws
  • Remove the six screws on the housing of the LCD.
    • Four 3.1mm Phillips screws on the side with the hinge.
    • Two 2.7mm Phillips screws
Remove the plastic back of the LCD.
  • Remove the plastic back of the LCD.
Unplug the blue cable attached to the back of the LCD. Unplug the blue cable attached to the back of the LCD.
  • Unplug the blue cable attached to the back of the LCD.
5 autre(s) ont terminé cette réparation.
Jordan Rabold
Membre depuis le 14/04/2014
607 Réputation
4 tutoriels rédigés
Équipe
Cal Poly, Team 12-33, Maness Spring 2014 Membre de l'équipe Cal Poly, Team 12-33, Maness Spring 2014
CPSU-MANESS-S14S12G33
4 membres
7 tutoriels rédigés
Voir les statistiques:
Dernières 24 heures : 1
7 derniers jours : 11
30 derniers jours : 34
Total : 3,515
