Introduction
Use this guide to replace a cosmetically damaged latch side cover.
Pièces
Aucune pièce nécessaire.
Remove the two 3mm (1/8") black screws from the side cover using a #00 Phillips screwdriver.
  • Remove the two 3mm (1/8") black screws from the side cover using a #00 Phillips screwdriver.
Ajouter un commentaire
On the bottom, remove the 6mm (13/64") screw with the #00 Phillips Screwdriver.
  • On the bottom, remove the 6mm (13/64") screw with the #00 Phillips Screwdriver.
  • Pry up the panel; starting from the front/bottom corner, as indicated.
    • There's a concealed lip, under the opposite edge.
Daniel Bussone
Membre depuis le 28/01/2011
1 206 Réputation
11 tutoriels rédigés
Équipe
Cal Poly, Team 3-41, Regan Winter 2011 Membre de l'équipe Cal Poly, Team 3-41, Regan Winter 2011
CPSU-REGAN-W11S3G41
2 membres
Voir les statistiques:
Dernières 24 heures : 0
7 derniers jours : 1
30 derniers jours : 4
Total : 1,626
