Introduction
Over the life of the printer the ink cartridges will have to be replaced multiple times. Before attempting to replace the ink cartridges ensure that the printer is working properly which will facilitate in the cartridge exchange.
The printer needs to be on in order to change the ink cartridges.
  • The printer needs to be on in order to change the ink cartridges.
Ajouter un commentaire
To locate the ink cartridges the paper output tray must be in the lowered position. Next lift the scanning unit until the scanning support is vertical. Lower the scanning unit until the scanning unit support seats in the scanning unit support slot.
  • To locate the ink cartridges the paper output tray must be in the lowered position.
  • Next lift the scanning unit until the scanning support is vertical.
  • Lower the scanning unit until the scanning unit support seats in the scanning unit support slot.
Allow the printer to position the ink cartridge carrier into the ink cartridge removal location. Before replacing the ink cartridge ensure the correct ink cartridge is installed. Push down on the front edge of the ink cartridge.
  • Allow the printer to position the ink cartridge carrier into the ink cartridge removal location.
    • Before replacing the ink cartridge ensure the correct ink cartridge is installed.
  • Push down on the front edge of the ink cartridge.
    • Observe the angle at which the ink cartridge is removed.
  • Grasp ink cartridge and pull up and out to remove.
4 autre(s) ont terminé cette réparation.
Garret Wescott
Membre depuis le 23/10/2014
591 Réputation
4 tutoriels rédigés
Équipe
Michigan Tech, Team 1-5, Lauer Fall 2014 Membre de l'équipe Michigan Tech, Team 1-5, Lauer Fall 2014
MTU-LAUER-F14S1G5
3 membres
5 tutoriels rédigés
Voir les statistiques:
Dernières 24 heures : 2
7 derniers jours : 24
30 derniers jours : 130
Total : 5,459
