Introduction
Replacing the command screen is relatively simple. You will have to pop off a few parts from the lid section of the printer in order to get at the back part of the command screen. Once you have access to the command screen and the attached chip, you can unplug a few wires and remove the screen with a philips-head screwdriver. After you have removed the screen, put in a replacement and close the printer back up. Good Luck!
Pièces
Aucune pièce nécessaire.
Open top lid of the printer to reveal the scanner
  • Open top lid of the printer to reveal the scanner
Ajouter un commentaire
Insert the spudger tool into the top lid  in between the blue and the black panels. Use this tool to pry the two panels apart
  • Insert the spudger tool into the top lid in between the blue and the black panels.
  • Use this tool to pry the two panels apart
After these two panels are separated, set the top panel to the side for now
  • After these two panels are separated, set the top panel to the side for now
Unplug the two wires shown at the right of the command screen
  • Unplug the two wires shown at the right of the command screen
Unscrew the four screws shown to detach the command screen from the printer
  • Unscrew the four screws shown to detach the command screen from the printer
Take the detached command screen off of the printer and replace.
  • Take the detached command screen off of the printer and replace.
4 autre(s) ont terminé cette réparation.
Val Fedorikhin
Membre depuis le 12/10/2014
848 Réputation
5 tutoriels rédigés
Équipe
Cal Poly, Team 6-21, Maness Fall 2014 Membre de l'équipe Cal Poly, Team 6-21, Maness Fall 2014
CPSU-MANESS-F14S6G21
4 membres
5 tutoriels rédigés
Voir les statistiques:
Dernières 24 heures : 2
7 derniers jours : 4
30 derniers jours : 17
Total : 576
