Introduction
If your cassette is broken it is easy to take out and replace. The cassette may also need to be removed if paper is jammed. Removal is simple and does not require tools.
Locate the cassette below the front paper output tray.
  • Locate the cassette below the front paper output tray.
Ajouter un commentaire
Reach underneath printer, fitting your fingers into the groove in the front of the cassette. Reach underneath printer, fitting your fingers into the groove in the front of the cassette.
  • Reach underneath printer, fitting your fingers into the groove in the front of the cassette.
Pull the cassette toward you. You have successfully removed the tray.
  • Pull the cassette toward you.
  • You have successfully removed the tray.
Caitlyn
Membre depuis le 07/10/2014
494 Réputation
4 tutoriels rédigés
Équipe
USF Tampa, Team 1-3, Leahy Fall 2014 Membre de l'équipe USF Tampa, Team 1-3, Leahy Fall 2014
USFT-LEAHY-F14S1G3
3 membres
4 tutoriels rédigés
Voir les statistiques:
Dernières 24 heures : 0
7 derniers jours : 4
30 derniers jours : 15
Total : 1,133
