Pièces
Aucune pièce nécessaire.
Open the battery door by sliding the tab on the battery door while pushing the battery door away from the camera. Remove batteries.
  • Open the battery door by sliding the tab on the battery door while pushing the battery door away from the camera.
  • Remove batteries.
Ajouter un commentaire
Remove the three indicated .2mm screws using a Philips #00 screwdriver. Gently pull off side-panel to remove it.
  • Remove the three indicated .2mm screws using a Philips #00 screwdriver.
  • Gently pull off side-panel to remove it.
Remove the two indicated .2mm screws using a Philips #00 screwdriver.
  • Remove the two indicated .2mm screws using a Philips #00 screwdriver.
Remove the indicated .2mm screw using a Philips #00 screwdriver. Remove the three .2mm screws located on the internal side of the top panel within the battery chamber using a Philips #00 screwdriver.
  • Remove the indicated .2mm screw using a Philips #00 screwdriver.
  • Remove the three .2mm screws located on the internal side of the top panel within the battery chamber using a Philips #00 screwdriver.
Open 'DIGITAL A/V OUT' door on camera. Remove the two indicated .2mm screws using a Philips #00 screwdriver.
  • Open 'DIGITAL A/V OUT' door on camera.
Grip the sides of the top panel and gently pull to separate the top panel from the camera body.
  • Grip the sides of the top panel and gently pull to separate the top panel from the camera body.
  • The top panel will not completely detach.
Gently pull the front and back panels apart, and use a Phillips #00 screwdriver to remove the screw connecting the panels. Gripping the top and bottom, gently pull the front panel away from the camera body to remove it.
  • Gently pull the front and back panels apart, and use a Phillips #00 screwdriver to remove the screw connecting the panels.
  • Gripping the top and bottom, gently pull the front panel away from the camera body to remove it.
Use the spudger to gently pull back the retaining clip and pull the ribbon out
  • Use the spudger to gently pull back the retaining clip and pull the ribbon out
  • The top panel should now be completely detached from the camera
  • Applying to much force to the spudger may damage the retaining clip
Remove the two screws holding down the metal frame using the Phillips #00 screwdriver
  • Remove the two screws holding down the metal frame using the Phillips #00 screwdriver
Lift up the metal frame to expose the two screws located under the trigger button.
  • Lift up the metal frame to expose the two screws located under the trigger button.
  • Remove the two screws using Phillips #00 screwdriver
Trigger button should fall out Trigger button should fall out
  • Trigger button should fall out
Kelly Duggan
Membre depuis le 13/10/2014
439 Réputation
3 tutoriels rédigés
Équipe
Clemson, Team 2-5, Benson Fall 2014 Membre de l'équipe Clemson, Team 2-5, Benson Fall 2014
CLEM-BENSON-F14S2G5
4 membres
9 tutoriels rédigés
Voir les statistiques:
Dernières 24 heures : 0
7 derniers jours : 2
30 derniers jours : 7
Total : 221
