Introduction
This guide serves to replace a faulty flash mechanism.
Remove the knot on the wrist lanyard. Remove the battery and memory card.
  • Remove the knot on the wrist lanyard.
  • Remove the battery and memory card.
Ajouter un commentaire
Remove all screws from sides of outer casing. Begin removing the screws on the bottom of the outer casing.
  • Remove all screws from sides of outer casing.
  • Begin removing the screws on the bottom of the outer casing.
  • Remove the rest of the screws from the outer casing.
Gently pull the front cover off the camera. Gently pull the front cover off the camera. Gently pull the front cover off the camera.
  • Gently pull the front cover off the camera.
Open the "A/V Out Digital" cover slide, and remove the screw inside. Gently pull off the back casing. Remove the black "L" shaped piece of metal.
  • Open the "A/V Out Digital" cover slide, and remove the screw inside.
  • Gently pull off the back casing.
  • Remove the black "L" shaped piece of metal.
Remove the three screws that are holding the screen in place and free the screen from the underlying components.
  • Remove the three screws that are holding the screen in place and free the screen from the underlying components.
  • Be careful of the ribbon wire that is still attached on the left of the screen.
Kits RAM pour Mac
Accélérez votre Mac. Maximisez sa mémoire.
Kits RAM pour Mac
Augmentez la mémoire de votre Mac.
With the spudger, gently lift the black flap that is holding the wide ribbon cable wire in place. Unplug the wide ribbon cable.
  • With the spudger, gently lift the black flap that is holding the wide ribbon cable wire in place.
  • Unplug the wide ribbon cable.
  • Unplug the narrow ribbon cable to free the LCD screen from the camera body
The author failed to mention a couple things. First, the screen is in a holder which you remove, then after pulling off some electrical tape, you have to yank the actual screen out. Second, I only had two screws to pull the screen holder out, not three. Third, the thing that you have to pull to get the screen ribbon cable out is actually a tiny black hinge, so don't worry if it suddenly snaps back. Finally, to put the thing back together, it really helps if you have a tweezers to get the ribbon cables back into place.
and fyi replacement screens available from canon parts department for about 50 bucks.
steven - Réponse
Remove the L-shaped corner trim containing the picture button.
  • Remove the L-shaped corner trim containing the picture button.
  • Carefully unplug the connection cable attached.
Pull the selector wheel from the top corner of the camera. With a set of tweezers, carefully remove the ribbon cable connection.
  • Pull the selector wheel from the top corner of the camera.
  • With a set of tweezers, carefully remove the ribbon cable connection.
Unscrew the zoom toggle switch and remove.
  • Unscrew the zoom toggle switch and remove.
Unscrew the flash board.
  • Unscrew the flash board.
With a metal spudger, gently pry up and remove the cable connection.
  • With a metal spudger, gently pry up and remove the cable connection.
  • With a metal spudger, gently lift up black tab to remove ribbon cable.
Lift the flash bulb unit from the camera.
  • Lift the flash bulb unit from the camera.
Lift the entire three-part flash assembly from the camera. Lift the entire three-part flash assembly from the camera.
  • Lift the entire three-part flash assembly from the camera.
BrettH
Membre depuis le 28/10/2009
219 Réputation
5 tutoriels rédigés
Équipe
Cal Poly, Team 19-5, Maness SU 2012 Membre de l'équipe Cal Poly, Team 19-5, Maness SU 2012
CPSU-MANESS-SU12S19G5
1 membre
5 tutoriels rédigés
Voir les statistiques:
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 0
Total : 3,422
