Aller au contenu principal
Canon PowerShot S80 Motherboard Replacement
Ce dont vous avez besoin
  1. Canon PowerShot S80 Motherboard Replacement, Outer Casing: étape 1, image 1 de 2 Canon PowerShot S80 Motherboard Replacement, Outer Casing: étape 1, image 2 de 2
    • Remove the knot on the wrist lanyard.
    • Remove the battery and the memory card.
  2. Canon PowerShot S80 Motherboard Replacement: étape 2, image 1 de 2 Canon PowerShot S80 Motherboard Replacement: étape 2, image 2 de 2
    • Begin removing the screws on the bottom of the outer casing.
    • Next, remove the rest of the screws from the outer casing.
  3. Canon PowerShot S80 Motherboard Replacement: étape 3, image 1 de 3 Canon PowerShot S80 Motherboard Replacement: étape 3, image 2 de 3 Canon PowerShot S80 Motherboard Replacement: étape 3, image 3 de 3
    • Gently pull the front cover off of the camera.
  4. Canon PowerShot S80 Motherboard Replacement: étape 4, image 1 de 3 Canon PowerShot S80 Motherboard Replacement: étape 4, image 2 de 3 Canon PowerShot S80 Motherboard Replacement: étape 4, image 3 de 3
    • Open the "A/V Out Digital" cover. Remove the screw inside.
    • Gently pull off the back casing.
    • Remove the black "L" shaped piece of metal.
  5. Canon PowerShot S80 Motherboard Replacement, LCD Screen: étape 5, image 1 de 1
    • Remove the three screws that are holding the screen in place. Free the screen from the underlying components.
    • Be careful with the ribbon wire that is still attached on the left side of the screen.
  6. Canon PowerShot S80 Motherboard Replacement: étape 6, image 1 de 2 Canon PowerShot S80 Motherboard Replacement: étape 6, image 2 de 2
    • With the spudger, gently lift the black flap that is holding the wide ribbon cable wire in place.
    • Unplug the wide ribbon cable.
    • Unplug the narrow ribbon cable to free the LCD screen from the camera body.
  7. Canon PowerShot S80 Motherboard Replacement, Motherboard: étape 7, image 1 de 1
    • Remove the screws holding down the function set button.
  8. Canon PowerShot S80 Motherboard Replacement: étape 8, image 1 de 1
    • Gently pry up the tab with a metal spudger and remove the ribbon cable.
  9. Canon PowerShot S80 Motherboard Replacement: étape 9, image 1 de 1
    • Be mindful of the pins as you lift up and remove the function/set button.
  10. Canon PowerShot S80 Motherboard Replacement: étape 10, image 1 de 3 Canon PowerShot S80 Motherboard Replacement: étape 10, image 2 de 3 Canon PowerShot S80 Motherboard Replacement: étape 10, image 3 de 3
    • Remove the screws from the metal plate.
    • Gently remove the metal plate.
  11. Canon PowerShot S80 Motherboard Replacement: étape 11, image 1 de 2 Canon PowerShot S80 Motherboard Replacement: étape 11, image 2 de 2
    • Lift the tab connecting the ribbon cable and detach.
  12. Canon PowerShot S80 Motherboard Replacement: étape 12, image 1 de 2 Canon PowerShot S80 Motherboard Replacement: étape 12, image 2 de 2
    • Use a spudger to lift up the ribbon cable tab.
    • Detach the ribbon cable.
  13. Canon PowerShot S80 Motherboard Replacement: étape 13, image 1 de 2 Canon PowerShot S80 Motherboard Replacement: étape 13, image 2 de 2
    • Gently remove the entire ribbon cable connection to release the ribbon cable from the camera.
  14. Canon PowerShot S80 Motherboard Replacement: étape 14, image 1 de 1
    • Unscrew the circuit board from the flash unit.
  15. Canon PowerShot S80 Motherboard Replacement: étape 15, image 1 de 3 Canon PowerShot S80 Motherboard Replacement: étape 15, image 2 de 3 Canon PowerShot S80 Motherboard Replacement: étape 15, image 3 de 3
    • Pry up the ribbon cable connection and remove it from the camera.
    • Lift the ribbon cable tab and completely detach the cable from the camera.
  16. Canon PowerShot S80 Motherboard Replacement: étape 16, image 1 de 1
    • Pry up the connection, being mindful of the light adhesive.
  17. Canon PowerShot S80 Motherboard Replacement: étape 17, image 1 de 1
    • Remove the last screw holding the motherboard to the main body.
  18. Canon PowerShot S80 Motherboard Replacement: étape 18, image 1 de 2 Canon PowerShot S80 Motherboard Replacement: étape 18, image 2 de 2
    • Use a spudger to gently lift the motherboard from the camera.
2 autres ont terminé cette réparation.
BrettH
Membre depuis le 10/28/09
219 Réputation
5 tutoriels rédigés
Équipe
Cal Poly, Team 19-5, Maness SU 2012 Membre de l'équipe Cal Poly, Team 19-5, Maness SU 2012
CPSU-MANESS-SU12S19G5
1 membre
5 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 6
30 derniers jours : 15
Total : 4,432
