Aller au contenu principal
Canon PowerShot SD1000 Lens Replacement
Ce dont vous avez besoin
  1. Canon PowerShot SD1000 Lens Replacement, Back Panel: étape 1, image 1 de 2 Canon PowerShot SD1000 Lens Replacement, Back Panel: étape 1, image 2 de 2
    • Remove the two 2.9 mm screws from the side panel closest to the camera lens.
  2. Canon PowerShot SD1000 Lens Replacement: étape 2, image 1 de 1
    • Remove the two 2.9 mm screws from the camera bottom panel.
  3. Canon PowerShot SD1000 Lens Replacement: étape 3, image 1 de 1
    • Remove the two 2.9 mm screws from the side panel farthest from the lens.
  4. Canon PowerShot SD1000 Lens Replacement: étape 4, image 1 de 1
    • Pull the back panel away from the camera body, starting at the end with the function buttons.
  5. Canon PowerShot SD1000 Lens Replacement: étape 5, image 1 de 1
    • Remove the small cover panel and the attached wrist strap mount.
  6. Canon PowerShot SD1000 Lens Replacement, Front Case: étape 6, image 1 de 1
    • Remove the front cover by gently pulling it away from the camera body.
  7. Canon PowerShot SD1000 Lens Replacement: étape 7, image 1 de 1
    • Place the front cover, back cover, and wrist strap mount in a safe place until you are ready for reassembly.
  8. Canon PowerShot SD1000 Lens Replacement, LCD Screen: étape 8, image 1 de 1
    • Remove the two 2.4 mm screws located at the top of the LCD panel.
  9. Canon PowerShot SD1000 Lens Replacement: étape 9, image 1 de 2 Canon PowerShot SD1000 Lens Replacement: étape 9, image 2 de 2
    • Pull up the metal frame surrounding the LCD screen starting at the side of the camera.
  10. Canon PowerShot SD1000 Lens Replacement: étape 10, image 1 de 1
    • Push the metal frame away from the metal tab using the spudger to detach the frame.
    • Rotate the metal frame upwards.
    • The metal framing should be attached by a metal tab towards the bottom of the camera, near the function buttons.
  11. Canon PowerShot SD1000 Lens Replacement: étape 11, image 1 de 2 Canon PowerShot SD1000 Lens Replacement: étape 11, image 2 de 2
    • Carefully lift the metal frame from the camera.
    • Remove the black LCD screen, leaving the thin lens pieces in place.
    • BE CAREFUL; both components are attached by an orange connector ribbon and cannot be removed yet.
  12. Canon PowerShot SD1000 Lens Replacement: étape 12, image 1 de 3 Canon PowerShot SD1000 Lens Replacement: étape 12, image 2 de 3 Canon PowerShot SD1000 Lens Replacement: étape 12, image 3 de 3
    • Carefully pull on the orange connector ribbon to disconnect the LCD screen.
    • The LCD screen can be pulled out of the frame before disconnecting its connector ribbon.
    • Tweezers are helpful to disconnect the ribbon.
  13. Canon PowerShot SD1000 Lens Replacement, Flash Unit: étape 13, image 1 de 2 Canon PowerShot SD1000 Lens Replacement, Flash Unit: étape 13, image 2 de 2
    • Slide the metal frame off of the camera on the side that is closest to the flash mechanism.
  14. Canon PowerShot SD1000 Lens Replacement: étape 14, image 1 de 1
    • Use a Phillips #00 screwdriver to remove the 2.4 mm screw that secures the flash assembly.
  15. Canon PowerShot SD1000 Lens Replacement: étape 15, image 1 de 1
    • Use the spudger to gently and carefully disconnect the flash assembly ribbon from the black connector lock.
  16. Canon PowerShot SD1000 Lens Replacement: étape 16, image 1 de 2 Canon PowerShot SD1000 Lens Replacement: étape 16, image 2 de 2
    • Pull the flash assembly forward out of the camera to remove it.
    • BE CAREFUL when handling the flash assembly. Touching the capacitor (the black cylinder attached to the flash assembly) could shock you.
  17. Canon PowerShot SD1000 Lens Replacement, Lens: étape 17, image 1 de 1
    • Remove the 2.90mm screw from the lens, near the motherboard.
  18. Canon PowerShot SD1000 Lens Replacement: étape 18, image 1 de 2 Canon PowerShot SD1000 Lens Replacement: étape 18, image 2 de 2
    • Using the spudger remove the shutter button by prying the small tab on the front side of the camera.
  19. Canon PowerShot SD1000 Lens Replacement: étape 19, image 1 de 2 Canon PowerShot SD1000 Lens Replacement: étape 19, image 2 de 2
    • With a spudger disconnect the orange connector ribbon as shown.
    • Disconnect the orange connector ribbon that is located under the now removed shutter button.
  20. Canon PowerShot SD1000 Lens Replacement: étape 20, image 1 de 1
    • Remove the two 2.90 mm screws from the motherboard.
  21. Canon PowerShot SD1000 Lens Replacement: étape 21, image 1 de 1
    • With Tweezers detach the bottom orange ribbon.
  22. Canon PowerShot SD1000 Lens Replacement: étape 22, image 1 de 1
    • Remove the screws shown. Start with the outside 6 (3-2.90mm & 3-2.40mm) screws on the metal frame. Then remove the 6 (2.40mm) screws on the back of the lens piece
  23. Canon PowerShot SD1000 Lens Replacement: étape 23, image 1 de 1
    • With spudger gently remove the Viewfinder Window that is directly above the lens.
  24. Canon PowerShot SD1000 Lens Replacement: étape 24, image 1 de 3 Canon PowerShot SD1000 Lens Replacement: étape 24, image 2 de 3 Canon PowerShot SD1000 Lens Replacement: étape 24, image 3 de 3
    • Detach the mother board with lens from body of camera.
    • Carefully remove the lens from the motherboard. Use tweezers to remove any of the 4 connecting ribbons from the lens.
    • Your lens has been removed from the motherboard and bottom framing.
4 autres ont terminé cette réparation.
Phillip Phung
Membre depuis le 01/19/12
624 Réputation
9 tutoriels rédigés
Équipe
Cal Poly, Team 8-18, Maness Winter 2012 Membre de l'équipe Cal Poly, Team 8-18, Maness Winter 2012
CPSU-MANESS-W12S8G18
4 membres
12 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 6
30 derniers jours : 28
Total : 4,571
